Old 09-14-2007, 09:11 PM
elalto is on a distinguished road
New Chuck, Have a Question
Hi All,
I just got a new lathe chuck for my 14x40 lathe, the chuck is a three jaw and has a cap head screw on either side of each jaw. My question is what are the screws for and how are they used??
Thanks in advance,
Marcos (elalto)
Old 09-15-2007, 12:17 AM
One of Many is on a distinguished road
If the cap head bolts are in the face of the chuck body, they bolt the body to the backing plate.
If these bolts go through the jaws, they are removable jaws and can be flipped around for large OD parts. This is also a feature handy for mounting soft jaws.
If these are around the chuck body OD, just behind the pinions, then they are for setting the chuck true to center. Set-true chucks are usually very high end quality. I wouldn't be without one, but a four jaw would do in a pinch.
If you have a manufacturer, model or web link for where you purchased this particular chuck, it would help identify the cap heads purpose.
DC
Learn cause and effect through experience. Mastering those relationships is the "Common Sense" ability within the art of any trade.
new lathe chuck skyway0018746 Metal Working Tooling 10 01-01-2008 12:36 PM
Q: Need 5C Chuck Deviant Mini Lathe 1 04-23-2007 03:15 PM
Chuck question snooper General Metalwork Discussion 3 09-21-2006 12:25 PM
Chuck Drill Chuck Alignment TomV Mini Lathe 5 04-27-2006 01:20 AM
air chuck bbrreid Mechanical Calculations/Engineering Design 4 11-20-2005 07:44 PM
