Old 09-13-2007, 06:04 PM
PoiToi is on a distinguished road
Lightbulb Cut Knurling??
Hello All, i'm pretty new here but have already found this to be an awesome community!!
I was wondering if anyone could give me any information on cut knurling, I work in a small production shop and was wondering if cut knurling 303 stainless would be any better than the normal way, and I just like to learn new things! ^_^
thanks!
Old 09-14-2007, 08:54 PM
crazythunder is on a distinguished road
Well it depends on the requirement and also the type of knurl you are needing to do. Time becomes the factor when you start cutting knurls verses the traditional way of using a knurl tool. I would contact my local tool vendor and have them come in to guide you with proper tool selection, speeds and feeds. It can be done just need to get the right tool to do the job and everything should go ok. Also make sure you use cutting oil coolant will give you big problems.
Old 09-15-2007, 12:30 PM
star-turn is on a distinguished road
Yes cut knurling is way, way better than the very outdated form knurling, i use cut knurls on everything from Ali to 316.
Apart from the initial cost of buying the tools/wheels i can set up quicker, repeat the knurl time and time again and run the job 5 to 6 times faster.
there is also less strain created on the CNC ballscrews etc..
ST
Straight knurling ??? turmite General Metalwork Discussion 5 09-11-2009 11:30 PM
knurling SAWMAN General Metalwork Discussion 14 03-16-2007 09:50 PM
Knurling SPEEDRE General Metalwork Discussion 4 10-03-2006 06:04 AM
Knurling larry53 General Metalwork Discussion 0 08-04-2006 07:29 PM
Knurling ? Ken_Shea General Metalwork Discussion 13 02-23-2004 10:17 AM
