I'm a rookie still at CNC machining but the bosses here at work think I'm pro. I got thrown into running, programing and set-up of all the CNC's at work. There is a boat load of indexable tooling to use. There problem I'm having is finding out what speeds and feeds to run it at. I know that you can run them a lot faster than your standard endmills and drills. Have some parts coming down the pipe soon that I would like to use this tooling on to increase run time, but have been unable to find how fast and how deep of cut I can use on this indexable tooling. Please help. Thanks Erlock |
| Indexable Feeds and Speeds (just the same as solid tooling) depends on the same variables... material, programed cutting method, setup, machine, spindle taper, HP, insert type and material, coated/uncoated, etc, etc. This also may vary some with different tool makers as well. Your best bet (for the time being) is to start thumbing through catalogs, websites, etc for the tool brand to get some baselines and starting points. Most of them will have at least that, including some trouble shooting guides. Once you have a more specific issue, post your questions and there will be plenty of folks here who can help... give a more specific example if you're in doubt of what to do. I would think though, your object is to decrease your run time.... not increase it.
__________________ It's just a part..... cutter still goes round and round.... |
| If it is a brand that your shop still deals with, call your salesman and ask him a bunch of the questions you need to know. At least he will be able to see the setup and machines, and can go from there. Better yet get a rep from the manufacturer to come in and help you out, these people usually know a lot about this sort of thing. Looking through catalogs can be very time consuming why not let a salesmen do it for you. Most salesmen are pretty good and have some machining back round, if you get a total dud then follow psychomills advice. People here are always willing to give a hand to a fellow metalworker. good luck
__________________ Live free or die |
| Checking with the sales rep is a good idea. Even when you have the tool in your hand, you may not know what grade insert is installed and that can make a huge difference in application. The insert for aluminum will be different from the one used on tool steel. Sometimes, there is a general purpose insert but with Iscar, Kennemetal, Valenite, and many other brands, they have specific grade inserts based on workpiece material. |
| who wants indexable tooling for their pc 892? | spoiledbrat | Polls | 3 | 04-14-2010 01:10 AM |
| Indexable insert tooling for newbies | Dan S | Mini Lathe | 11 | 12-30-2006 05:02 AM |
| Indexable tooling | Davidimurray | Mini Lathe | 2 | 11-18-2006 09:46 PM |
| Name This Indexable Drill | JFettig | General Metal Working Machines | 8 | 05-08-2006 01:26 PM |
| Indexable Head ?? | rcazwillis | General Metalwork Discussion | 8 | 05-31-2005 09:01 AM |
