Old 08-25-2007, 06:13 AM
ozzie34231 is on a distinguished road
Metal dust
My belt sander says, "Do not use vacuum if sanding metal".
Is there a real danger of explosion when collecting metal dust, or is this theoretical garbage?
I'm sanding aluminum most of the time.
Jerry
Old 08-25-2007, 07:08 AM
Gold Member
Ken_Shea is on a distinguished road
Jerry,
Does it warn of explosion ??
My guess is not that it would be explosive but that it would draw the abrasive dust up and into areas causing excessive wear.
Ken
Old 08-25-2007, 07:29 AM
bbj bbj is offline
bbj is on a distinguished road
well mixing metals could be disastrous. Steel dust will eventually rust and if you happen to have aluminum powder in there aswell, then you have a potentially lethal mix. A sufficiently hot heatsrouce will ignite it and it burns hot enough to almost instantly melt steel . I forget what that mixture is called now......
John
Old 08-25-2007, 08:47 AM
The name bbj cannot remember is Thermite; the reaction between powdered aluminum and iron oxide that can generate temperatures of up 3500 C., certainly enough to melt steel.
It is a small but real risk.
Old 08-25-2007, 09:07 AM
Thanks All,
I just re-read the label.
It says to prevent a possible fire hazard do not use this when sanding metal.
Jerry
Old 08-25-2007, 11:04 AM
John3 is on a distinguished road
Not That Small of a Risk!
Powdered anything, especially powdered aluminum, powdered steel or worse yet a combination (thermite) is very explosive. Last year when things were a little slow at our shop. We emptied the dust collector and threw a pound or two of dust in a fire. The explosion was truly frightening.
After that I ditched two brush motor shop vacs because the guys would use them to pickup aluminum and steel dust.
Check out these links:
http://www.firemarshals.org/docs/Hay...n_and_Fire.pdf
http://www.youtube.com/watch?v=pIqC610k1gY
http://www.sparkdetection.com/proble...explosions.htm
Because of the explosion possibility, OSHA requires any dust collectors be statically grounded and place out side of buildings if they contain aluminum dusts.
John
Old 08-25-2007, 11:18 AM
Re: Not That Small Of A Risk
Yes I should have made it clear that I was talking in the context of a small belt sander with something happening spontaneously under normal usage.
Thermite itself, that is the iron oxide aluminum powder mix, burns very fast but it is not explosive. However, as you demonstrated the fine powder thrown into a flame burns so fast it is pretty close to an explosion.
Probably everyone in North America has seen the thermite reaction in operation; that is what occurs in the Space Shuttle solid boosters.
Old 08-25-2007, 03:12 PM
Gold Member
It seems the greatest risk for fire would be to have used the sander on wood and the dust being vacuumed into a container, then used on metal where sparks would surely occur and them sent off into the wood dust.
My dust shoe IQChallenged CNC Wood Router Project Log 10 03-04-2011 09:05 PM
Build cnc router without linear ball bearings ?? Flat metal on flat metal with lube ? vroemm Linear and Rotary Motion 7 08-16-2007 12:26 PM
Dust collector SPEEDRE DIY-CNC Router Table Machines 4 06-30-2007 08:45 AM
Dust Mask or No Dust Mask Hogpaw CNC Plasma and Waterjet Machines 0 09-08-2006 05:57 AM
Dust/Chip Control...CNC Dust Enclosures Too_Many_Tools DIY-CNC Router Table Machines 17 07-29-2006 01:44 PM
