08-24-2007, 10:24 AM
It's easy to make one.. | |
Originally Posted by OLD_Newbie I am trying to find a supplier that sells a tool that will drill and chamfer holes at the same time in steel. I need the drill size to be for an M6. (.197-.201) Any leads would be appreciated. |
My solution to this has been to use a center drill, and turn the chamfering part to the correct angle on the lathe using some of the fancy turning tool tips that will allow you to machine HSS. After I have the correct angle, I just hand grind some clearance as the turned surface would just rub.
If the center drill is not long enough, you can drill up the centre of one with a carbide drill, then put a 6mm (tapping) drill up the middle, and weld at the end that doesn't matter. Any good toolmaker should be able to knock one up in an hour.
__________________ Super X3. 3600rpm. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way.
Reason: typo
