Old 08-18-2007, 05:44 AM
Pete-C is on a distinguished road
Please help, making PVC marking jig?
Hi.
I would like to mark a round pvc pipe 50 mm in diameter
to drill holes say every 3 cm apart the whole length of the pipe top bottom side to side, my problem is i would like to know how i can make a simple jig, i am not any kind of engineer or anything, i thought to post here for you guys are all experts, and would know how i can make a simple jig to get accurate markings on the pipe.
I have thought about getting a 60 mm pipe, make the markings manually on the 60mm, and then put the 50mm inside the 60 mm, that way i can mark away easily.
Problem is, i cannot find 60mm diameter pipes of any kind anywhere, or am i not looking at the right place, i am in South-Africa, where can i look for something like that or is there an easier way?
Thanks, btw, it's for personal hobby purposes.
Old 08-18-2007, 09:26 AM
One of Many is on a distinguished road
How long is each pipe section?
How big are the holes?
Where are the hole patterns in relation to the pipe ends?
DC
Learn cause and effect through experience. Mastering those relationships is the "Common Sense" ability within the art of any trade.
Old 08-18-2007, 09:39 AM
Make a long trough out of wood that the pipe just fits in. Drill one hole in the pipe and have a hole in the side of the trough that lines up. Put a pin through these holes and your pipe is fixed in the trough. Now lay out all the other holes using the sides of the trough as a reference.
Alternatively you can make a shoe that slides along the top of the trough and fix a small bench drill onto this. Then you just have marks along the side of the trough, slide the shoe/drill along and drill holes at each mark.
Laser Marking Clear Anodized Al petriej Engraving Machines 12 10-04-2010 06:16 PM
laser marking machine for metal JennyYin Product Announcements & Manufacturer News 0 07-05-2007 11:07 PM
Fibre Laser Marking Machine JennyYin Product Announcements & Manufacturer News 0 02-09-2007 02:12 AM
Marking a degree wheel tafc General Metalwork Discussion 4 09-16-2006 09:46 AM
Simple CNC marking/writing apparatus? kywoodwrkr DIY-CNC Router Table Machines 16 03-03-2005 08:58 AM
