Hi, I drew this quickly on deltacad and I wanted to ask you guros how do I mount this without having horizontal movement? I picked those bearings to ease of installment. If you guys have a better idea on bearings and how to keep it from sliding, I would greatly appreciate the forth knowledge.
Little info about the drawing: The 3/8" wall is to separate the mountd blade from the motor and or user for safety issues. The shaft sits on two pillow block bearings and at the end, there is a pulley attached to connect to the motor.
I posted elsewhere (engineering forum) and I think it's wrong so I posted here again.
