Hello All, I am anxiously awaiting my new Syil Super X3 mill and C6 lathe. I have been reading just about everything I can find on the topic, but there are a few things I'm not quite sure about. 1. How do you know what the parameters are for creating large diameter threads so that they will be compatible with a particular screw or nut? Is there a spec for this somewhere that can be used in a CAD program? 2. What is the best way to create threads inside of a large diameter hole (1.5" for example)? 3. How do you cut a key slot inside of a hollow shaft? 4. What is the best way to align the work piece on a mill when you will need to move the work piece to deal with mill size restrictions? 5. What is the best way to drill/tap hole on the edge of 1/2" plate? Any advice will be much appreciated. Thanks, -S |
| I'll try to answer your questions in order. 1/ Go buy a Machinery's Handbook. It's a fat green book that has the numbers on any thread you might want to cut. That book was the first thing they made me buy when I started in the trade. 2/ you have to single point turn it in a lathe, if you can't get a tap. 3/Use a broach and a broaching bushing......look it up in the book! 4/Get some dowel pins that fit your tee slots on your mill table. 5/ Use a large angle plate and hang the part off the back of the mill table, then swing the mill head around over the part. Good luck!!
__________________ Be carefull what you wish for, you might get it. |
| I hate to sound like an old timer, but for "3. How do you cut a key slot inside of a hollow shaft?" (I interpret as internal keyseating) and jrom's method is easiest, however If you have a shaper, this is a good excuse to use it. I've done it on a lathe, and a mill also (manual, not cnc) and this procedure is a pita , only to be resorted to in emergency situations, or by the very,very cheap. (too frugal to dish out the money for a broach set + press.) My brother got a used American made DuMont set of broaches and bushings for < 100USD. But he's almost a mile away, and his set doesn't cover metric, so I often end up using the little shaper for this task. Now, if you HAVE to do it on a cnc mill it can be done, assuming you can orient the spindle precisely, and lock it there. This procedure is strongly discouraged and I would suggest using jrom's broaching method. But, if the spindle can be oriented, and locked, it is theoretically possible to (get ready to cringe folks) use the z axis to "emulate" a shaper's ram. A single point key seating tool (looks similar to a boring bar) with a properly ground tool bit is "pecked" with very conservative feedrate to produce the internal slot. Who would do this? Not me. Unless I HAD to have the internal keyway right now, regardless of the costs and risks.(and who has ever actually been in that position?) Again, listen to jrom and get a broach set! Or, to mollify the more enlightened, an edm machine (what can't they do?) sigipa, PLEASE don't use the method I described to cut internal keyways on your brand new machines! It is only offered for theoretical curiosity. Now, to make a long post even longer, if you are a hobbyist , you could consider using your new mill and lathe to build either an internal keyseater, or a metal shaper. But these are tools you will not be using very often*, and jrom's approach is again the wiser one. * a shaper only seems indispensable to someone that has one. |
| This guy needs help. He may not be in the right forum to get it. I would suggest that he be pointed to a basic machining how-to site. I don't know of any. Several members have expressed (correctly) that many new cnc'ers want to jump into programming without ever cutting a chip manually (my apologies to sipka if he has more experience than his post implies). This is a re-curring theme. Some of us (older) guys may not identify with this phenomena, since we were exposed to manual machines years before we ever saw a cnc. If you remember how fascinated you were when you first saw a long chip coming off a steel bar in a lathe in your youth, imagine how much more fascinating it would be to see the same thing, but no person operating the machine? Its a combination of what amazed us, years ago, PLUS the added factor that a computer is actually doing/making something. It is my belief that it would be easier to teach a 70 year old machinist to program,set-up and operate a cnc machining center than it would be to teach the same to a (typical) 20 something computer programmer. No offense intended to either age group, or either profession. |
| Hi, I appreciate everyone's input. JROM: I've been doing a lot of reading, but I missed this book somehow. Wow... what a resource. I wish I would have known about it sooner. Thanks very much for the pointer. You are all absolutely right. I have absolutely no clue what I'm doing. However, as near as I can tell, my project needs don't required anything that would be considered particularly difficult fabrication wise. I have purchased a bunch of scrap metal. My plan is to draw up my parts, send them to the machine, and keep reading and tweaking until I am able to produce all of the features that my parts need. If I have to go through a few hundred pounds of material and tools to get there, so be it. Damn the torpedoes! Many thanks to all, -S |
| CNC mill questions - thrust bearings, leadscrew mounting, general questions | tonofsteel | DIY-CNC Router Table Machines | 8 | 02-03-2012 03:42 PM |
| General CNC questions | dmparrott | DIY-CNC Router Table Machines | 1 | 01-24-2007 08:16 PM |
| general newbie question | charper | Vacuum forming, Thermoforming Etc | 15 | 11-29-2006 09:51 AM |
| new guy with a cnc lathe general questions | LOGBOSS | General Metal Working Machines | 1 | 05-07-2006 04:41 PM |
| Bringing objects together in V19 & general questions | rustyolddo | BobCad-Cam | 1 | 07-31-2004 09:14 AM |
