Old 08-15-2007, 02:40 PM
jackson's Avatar
jackson is on a distinguished road
Metric Threads
Just have a question probably a dumb one but never the less a question. i dont do much metric threading and when i do i just kinda fug my way through it. i though it was about time i asked how do you convert or figure out your TPI on a metric thread the one i am doing today is a M18 x 1.5 6g
thank you
individual who perceives a solution and is willing to take command. Very often, that individual is crazy.
Old 08-15-2007, 03:53 PM
M-man is on a distinguished road
25,4 / metric pitch = TPI....
THread dia -(0.1*metricpitch) /25.4 will give you a good dia of shaft before threading..
Take 18-1.5 to get bore dia for ID thread.
Old 08-15-2007, 03:59 PM
Another way to calculate pitch is use 1.000mm = 0.039370" so 1.5 mm is 0.059055".
Old 08-15-2007, 04:02 PM
jackson's Avatar
yeah it took me a min. but i figured it out then take 1. / .059055 = your tpi
and M-man's way works to. thanks i appreciate it
Old 08-15-2007, 04:23 PM
jackson's Avatar
ok i come up with a diferent answer doing it M-mans way the way you show it comes up 16.949 tpi his it comes out 16.3333 the 1.5 / .03937 is the way i origanly went with
Old 08-15-2007, 05:05 PM
My calculator gives 25.4/1.5 = 16.933333
1.5 * 0.03937 = 0.059055
1/0.059055 = 16.933367
If you want to get really precise the 0.03937 is only an approximation. It is actually 1/25.4 = 0.03937007
So 1.5 * 0.03937007 = 0.0590551
1/0.0590551 = 16.933338
Old 08-16-2007, 08:10 AM
jackson's Avatar
I see i was not finishing the .059055 i was just using .0590 that makes more cents
thanks Geof
Rigid tapping metric threads msomerville Milltronics 14 07-10-2007 09:47 PM
Looking for a Metric equivalent to ACME threads! widgitmaster Linear and Rotary Motion 4 02-10-2007 08:12 PM
The Metric System single phase Hypermill 3 11-13-2006 09:51 AM
DRO - Metric or Inch DJ Morrow General Electronics Discussion 2 11-15-2004 02:06 PM
Saving threads or parts of threads??? flybynight Forum Questions or Problems 4 02-22-2004 12:19 AM
