I'm not sure what these things are called otherwise I would just google it. We have a few granite blocks that I am told are very high-precision. We also have a granite slab and "high-precision" granite shims. What are these things generically called and what would they usually be used for? Especially the granite slab. I was using it to make sure all the inserts on a face mill parallel while tightening them down. Not sure if that would be considered abuse. ![]() Thanks. |
| They're used as a reference straightedge for indicators and other measuring gear. Height gauges, indicator stands w/ dial test indicators, et cetera all need some sort of nominally flat reference surface to work from. The surface plate, granite parallels, and what have you all give that "reference" plane that can be assumed flat/parallel/perpendicular/whatever you need for the purposes of measurement. For instance, you can check the wavyness of a long bar on a big surface plate. Take an indicator on a stand, and just slide the indicator base along the plate to get your measurement. Since the plate will be flat to some tolerance, you can get a accurate measurement of your flat bar +/- whatever the indicator and plate error are. |
| Assuming that you aren't scratching the surface plate, it shouldn't hurt. Small surface plates are pretty cheap, anyway. It is NOT sufficient, though, that the insert edges be coplaner, though. You want the plane that they are on to be perpendicular to the axis of the tool. Ken
__________________ Kenneth Lerman 55 Main Street Newtown, CT 06470 |
| I was very careful to not scratch the surface plate. It's interesting comment about the inserts being coplanar. How should one usually install inserts? I was told to that they align themselves but I was trying to be a bit more accurate using the surface plate. Thanks. |
| while its fair enough to say if it's a cheapo surface plate I'll do it anyway, none of this stuff should be used to align inserts in the sense that its precision inspection tackle you are talking about. surface plates can be cheap - the glued together Indian composites or expensive - the Starrett AA grade etc. the blocks and what you call shims (likely parallels) can be very expensive. price out Starrett's granite master squares and parallels for example - they should be treated with a lot care and used for inspection only to minimize exposure to wear/damage . Point is, what you are doing is probably ok if its the cheap stuff, but i wouldn't do it with the good stuff |
| Engraving Granite? | Cold Fusion | Glass, Plastic and Stone | 17 | 03-02-2008 08:48 PM |
| Very high precision DIY CNC router? | kenny1 | Open Source CNC Machine Designs | 9 | 02-05-2007 10:24 PM |
| Engraving Granite | nonnsgranite | General Material Machining Solutions | 0 | 08-03-2006 06:03 AM |
| running high Amp steppers question. | Semisentient | Xylotex | 1 | 04-21-2006 05:59 PM |
| precision servos (digital) vs. precision stepper (<3.6degree step angle) | bennyben | Servo Motors and Drives | 6 | 03-05-2004 10:11 PM |
