You could fill the gear up with one of the metallic epoxies and turn it down, But I assume you have Universal motor right now? hence the noise?
The only problem you may run into with the DC motor is rpm limit unless the motor is large enough to gear up, as DC Motors traditionally are fairly low rpm, 2000 ~ 3000 max, for router applications.
LinkBack URL
About LinkBacks
