Old 08-07-2007, 03:55 PM
bowhunter is on a distinguished road
.0625 face groove
having a little trouble with this one. i've been trying to do an internal face groove that is .0625 wide and .0625 deep but it starts at a depth of -1.000 on a diameter of 1.125 . I tried using a thinbit holder and only succeeded in breaking alot of inserts the material is 304 stainless. I also tried using the G74 face groove pecking cycle but to no avail. any pointers i'd appreciate them. thanks
Old 08-07-2007, 04:39 PM
bborb is on a distinguished road
A trepanning tool may be the answer.
Old 08-07-2007, 04:40 PM
tobyaxis's Avatar
Moderator
tobyaxis is on a distinguished road
Have you tried High Speed Steel yet??? In some applications your better off with a tool that can flex a little and absorb the shock. Flood Coolant, light pecks, low feeds and speeds.
Try these guys too, they make good Trepanning Tools.
http://www.hornusa.com/eng/products/...e_grooving.htm
Not to say anything but make sure you have a good clearance on the heel of the tool. If it is too big or too small it will break.
Hope this helps a little.
Cheers!!!!
Toby D.
"Imagination and Memory are but one thing, but for divers considerations have divers names"
Schwarzwald
www.refractotech.com
Old 08-07-2007, 04:47 PM
One of Many is on a distinguished road
Depends on what you are using. Have you looked into face grooving inserts and holders?
Personally I would grind my own carbide bit if it were a small run, but having the holder system sure is a blessing if they are reliable that thin.
Sandvik options
DC
Learn cause and effect through experience. Mastering those relationships is the "Common Sense" ability within the art of any trade.
Old 08-07-2007, 05:18 PM
big_mak is on a distinguished road
iscar picco tools may do the trick
"It's only funny until some one get's hurt, and then it's just hilarious!!" Mike Patton - Faith No More Ricochet
Old 08-07-2007, 06:33 PM
tobyaxis's Avatar
Moderator
http://www.iscar.com/ProductUpdate/P...MenuItemID3=14
Toby D.
Schwarzwald
Old 08-08-2007, 04:49 AM
eject_21 is on a distinguished road
can we see your code? when does it break? feed? speed? make sure your on center and the insert is correct for that diameter.I had a problem once when the tool made a series of rough pecks, then went to semi-finish without retracting enough in Z. Watch the tool run and see where its breaking.In 304 ss I would be at 280 sfpm, f.001 for the initial rough pecks. S320 f.002 for finishing.My guess is your tools off-center.
Old 08-08-2007, 06:51 AM
tobyaxis's Avatar
Moderator
I forgot to add that End Mills with a few Flute ground off work great for Trepanning. Sorry this was missed, been on a Mill for a while.
Some times I wish our brains where like Hard Drives that could be Searched LOL.
Toby D.
Schwarzwald
precision punch and die set - .0625" thick neoprene widgitmaster General Material Machining Solutions 2 12-07-2006 05:03 AM
Where to get this v-groove guide at? WarrenW Linear and Rotary Motion 1 06-26-2006 03:07 PM
V groove casters AustinT Linear and Rotary Motion 4 12-24-2005 11:44 PM
angular contact bearings face to face?? powerfade DIY-CNC Router Table Machines 2 06-18-2005 11:01 PM
