Old 08-05-2007, 05:10 PM
NShiflet is on a distinguished road
SFPM explained?
I'm training new lathe operators and need practical examples that explain surface feet per minute?
Old 08-06-2007, 03:45 PM
*Registered User*
Glacern is on a distinguished road
For a lathe, SFM = the number of feet per minute the outer diameter of the workpiece travels.
So if you've got a 4" diameter bar spinning at 100RPM,
SFM = circumference in feet * RPM
= 2 * pi * r * RPM
= 2 * 3 * 1/6 foot * 100 RPM
= 100 SFM
I rounded down pi, which is what I usually do for ease of calculation. That little .14 doesn't really matter.
If you were calculating SFM on a mill, same formula but you use the cutter radius instead of the workpiece radius.
Old 08-06-2007, 04:25 PM
bborb is on a distinguished road
If you touch a 1 inch grinding wheel thats spinning at 60 RPM, just over 3 inches of grinding surface travels across your finger in one second.
If you touch a 24 inch grinding wheel spinning at the same RPM, over 75 inches of grinding surface travels across your finger in one second. Now if you slow the 24 inch wheel way down to just over 2 RPM, then you're back to 3 inches of grinding surface traveling across your finger in one second.
The moral is, the larger "something" gets, the slower you want to spin it to keep the effects the same.
Old 08-06-2007, 09:20 PM
timlkallam is on a distinguished road
SFM = ( RPM x DIA ) / 3.82
RPM = ( SFM x 3.82 ) / DIA
Tim
Old 08-06-2007, 09:42 PM
Do you want a non-machine tool example? On a car travelling at 60mph the SFPM on the tire relative to the vehicle is 5280.
Old 08-07-2007, 08:18 AM
Thanks Geof,
Yes I have a lot of technical information so I was looking for non-machine examples to give more simple everyday ways to help understand.
Old 08-07-2007, 08:28 AM
The car can also be used to explain 'relative to'. Relative to the road the periphery of the wheel is stationary.
Another peripheral speed example is the Merry-Go-Round at the Fair; how fast do you need to run to keep up with Johnny when it is a certain diameter going at a certain rpm.
On the technical side but removed from lathes are chain and belt drives; the pulleys or sprockets have the same SFPM, they have to or the belt/chain is slipping, but different rpm.
HuFlungDung's Avatar
Moderator
Or, if the muffler is dragging beneath the vehicle, the road surface is grinding the muffler at 5280 feet/min at a vehicle speed of 60 mph
Old 08-07-2007, 08:34 AM
Which is about correct for grinding; 6" dia at 3500 rpm.
Ball End Mills - Dynamic SFPM/IPM M30 General Metalwork Discussion 3 07-24-2007 11:58 AM
dac explained R.thayer General Electronics Discussion 4 12-15-2006 11:41 AM
CNC Routers explained. Looking for a detailed guide (newbies level) RunningWild DIY-CNC Router Table Machines 0 09-25-2005 02:23 PM
Amps, Volts, Watts, explained ynneb DIY-CNC Router Table Machines 2 04-28-2004 06:11 PM
SFPM for dielectric canvas phenolic ?? Rekd Machine Problems, Solutions , Wireless DNC, serial port 3 08-06-2003 01:21 AM
