Results 1 to 6 of 6
Thread: Hitachi Sieki Hi-Cell 250 mill/turn
    Jul 2007
    Question Hitachi Sieki Hi-Cell 250 mill/turn
    We have had this machine for 4 years and never tried any milling with it. Now we are trying to figure it out and having trouble with cutter compensation. Round holes are getting oval using cutter comp. Anyone out there familiar with this machine? It has a Siecos 18T control.
    Registered CNCRim's Avatar
    Feb 2006
    I used to work with one exact same model but no full C-axis. Anyway my suspect is program could be wrong code or your live tool location maybe in the wrong place.
    Post a picture with geometry and attach a program with it see we can help you.......
    Jul 2007
    mill/turn
    Here is the part. The part is being held in the chuck by the round end.The following code is ramp milling one of the corner thru holes. See the cutter comp codes. The X offset register was used to open the holes. Note the G0 C0 after the tool change. This was added to reorientate the C axis to C0 at every tool change.
    (.375 END MILL)
    ( RAMP OUT 14.5 MM HOLES THRU )
    M666
    T023800 G17 G140 M5
    G98 M43
    T993800
    G28 U0.
    G28 H0.
    G0 C0
    G50 C0.
    T023800 B0
    G262 G97 G145 S1750 M13
    G00 X3.58 Z.25 M09
    C123.358
    Z.1
    G01 Z.025 F7.
    X3.7212 Z.0138 C121.938 F234.99
    X3.8095 Z.0069 C121.113 F220.82
    G41 X3.8986 Z0. C120.326 F210.77
    X3.9149 Z-.0013 C120.838 F371.28
    X3.9244 Z-.0025 C121.382 F395.89
    X3.9267 Z-.0037 C121.942 F407.04
    X3.922 Z-.005 C122.499
    X3.9102 Z-.0063 C123.034 F389.1
    X3.8918 Z-.0075 C123.529 F360.33
    X3.8674 Z-.0088 C123.968 F318.97
    X3.8379 Z-.01 C124.334 F265.85
    Jul 2007
    photo did not come in but it is in my gallery if you want to see it.
    Nov 2006
    Make sure you don't have any values in the wear offset page for the tool.
    Feb 2006
    it seem you are trying to cut thread with C-axis and 3-axis simutate, I don't think you can comp the reason was G17 G18 G19 machine only allow to comp in 2-axis only.
    1. Mori-Sieki MH630
      By Bluesman in forum Mori lathes
      Last Post: 11-19-2007, 05:53 PM
    2. Mill/turn...
      By M-man in forum General Metalwork Discussion
      Last Post: 02-15-2007, 05:29 AM
    3. mill/turn on a cin turn
      By Robert Timby in forum General Metal Working Machines
      Last Post: 01-31-2007, 11:33 PM
    4. Cin Turn turn/mill
      By Robert Timby in forum General CNC (Mill and Lathe) Control Software (NC)
      Last Post: 01-24-2007, 08:12 PM
    5. Surfcam mill/turn
      By CNCRim in forum G-Code Programing
      Last Post: 07-23-2006, 11:42 AM
