Old 07-27-2007, 07:02 PM
skmetal7 is on a distinguished road
Best way to make this part
I have a few parts that I want to make, or have made. It's a reed cut out of .005" shim stock. I would like the edges to be very smooth. EDM? Laser cut? Waterjet? There is a very small radius (.005") that I'm concerned about, and wondering if a laser beam can go that small, or a jet of water.
ID:	41362   Click image for larger version
Old 07-27-2007, 07:30 PM
tobyaxis's Avatar
Moderator
tobyaxis is on a distinguished road
I have no experience with Water Jet, EDM, or Lasers but am interested in the suggestions that you will get. This should make for an educational read.
Sorry I couldn't help.
Toby D.
"Imagination and Memory are but one thing, but for divers considerations have divers names"
Schwarzwald
www.refractotech.com
Old 07-27-2007, 11:09 PM
laka is on a distinguished road
As far as Water Jet, the smallest nozzle size i've seen is 0.020" diameter
Old 07-27-2007, 11:24 PM
EDM. I have never used it but from what I have read this would likely be the only method.
Water jet cannot go small enough.
With laser the piercing action would would leave a rough spot.
With EDM the electrode is machined to the precise shape that you need and the cut comes out minimally larger.
Your check book will need to be in a good state of health.
Old 07-28-2007, 03:12 AM
tobyaxis's Avatar
Moderator
That sounds like it would be expensive to have an electrode made from Graphite.
Toby D.
Schwarzwald
Old 07-28-2007, 10:09 AM
yoopertool is on a distinguished road
Am I correct to say that the three blue U shaped things on your drawing are flaps for the reed? If those are flaps then I dont know of anything other than a wire EDM which will leave you a nice finish and hold your tolerances. The only snag associated with a wire EDM is that you need to have a hole already in the piece for the wire to feed through and it would have to be larger than the wire. Common EDM wire has a diameter between .008 - .014. You may be able to find someone with smaller wire. There are several companies that make very small drill bits that you could use for starter holes such as this one:
http://www.minitoolinc.com/microdrillingandpunching.htm
EDM time is not cheap, but those parts are very thin and would cut extremely fast. You would just have to supply them with material that already has the starter holes in it. Good Luck!
Old 07-28-2007, 11:04 AM
tobyaxis's Avatar
Moderator
This is getting very interesting. I wonder if it would be possible to Stamp these parts with a Die. Is this possible??
Toby D.
Schwarzwald
Old 07-28-2007, 11:31 AM
thanks for all the responses!
I was thinking about stamping them but I don't even want to think about the price of a die being made, and I only need 2 of each.
I could possible make the radius larger, let me take a look
Old 07-28-2007, 11:32 AM
You could find a way to stamp it, but you probably wont get the nice finish that is desired. Also, you wouldnt be able to get the gap needed for the reeds unless a complicated or 2-stage die was made. If this was a mass production job, then stamping could be considered, but not with only a few pieces.
Old 07-28-2007, 11:53 AM
yes those are the flaps, and I'm not sure how drilling .005" shim stock would work, sheet metal sucks to drill to begin with.
I made the radius now .01", so the width of the "u" shape groove is now .02". Is that a more standard size? it can still go a bit larger, but I want to leave room for tolerances.
can you drill down with wire edm? If I went with a laser cut edge how rough would that edge be?
I'm playing with a .004" feeler gauge here with me and thinking about how thin this is gonna be.
  #11   Ban this user!
Old 07-28-2007, 03:46 PM
Skeeterd5150 is on a distinguished road
I was thinking. This might sound really dumb but what if you lay it out with a hand scribe and keep going over the lines with it. I mean when you scribe something you are actually cutting it. So you really don't have very far to go down before you get to the other side. .005 isn't very much.
  #12   Ban this user!
Old 07-28-2007, 05:08 PM
bigbunny5's Avatar
bigbunny5 is on a distinguished road
I may be reading that Scrrenshot wrong, but if you are only talking about .005 thick parts have you thought about using an Electro Chem Etching Processes?
An idea that is not dangerous is unworthy of being called an idea at all, and Consistency is the last refuge of the unimaginative.
Would any DIYers (in the US) be willing to make a part for me? 11bravo CNCzone Club House 14 04-02-2007 03:04 PM
CNC able to make this? kentrob11 Hobby Discussion 92 03-09-2006 08:30 AM
what's biggest part you can make on an X2 sanddrag Benchtop Machines 2 03-04-2006 12:58 AM
How to copy existing part to make a mold? dbassett74 Moldmaking 30 11-08-2004 07:20 PM
