Old 07-17-2007, 03:01 PM
deleteallusers is on a distinguished road
Specific drill bit needed ?
I've got to drill ALLOT of holes in the Black Acrylic panel
I’m using to cover the PCB. Around 768 of them !
I got a good DIY CNC machine that uses a dermel tool for the spindle.
I think it will do the job and I’m currently designing the CAM file for drilling the holes.
However, I need a drill bit that can cut a 13/64, and at the same time fit into a dremel tool which is 1/8 inch shank.
Does anyone know where can I find this? Is there an alternative solution I can use?
What do other people use ? I thought about this bit
http://www.truebite.com/drill_degrout/
It’s part no# 6050 – but will it not remove a plug of the material and clog the bit each time I plunge through the material?
I really ned some help, I don’t know what to do.
Thanks,
Old 07-18-2007, 05:14 AM
HIRAH is on a distinguished road
you can get a carbide circuit board drill in that size with an 1/8" shank.
.500 flute. they are about $20 each at msc.
Old 07-18-2007, 09:59 AM
Thanks Hirah !
Yes they have one, I've looked everywhere for
a bit like this, Thanks !
It's msc part no. #00901132
Specific (CNC) code request. Karol General CNC (Mill and Lathe) Control Software (NC) 3 06-22-2007 09:30 PM
What speeds and feed are needed to weld a SML drill into 303SS? cacrawfo CNC Tooling 7 05-14-2007 12:31 PM
Specific purpose for Vcarve Hack Vectric 8 04-04-2007 09:20 AM
Which mill for specific job fatboy55 Benchtop Machines 7 08-05-2006 08:36 PM
Specific Power supply ? boxwood General Electronics Discussion 6 05-17-2003 12:26 PM
