Old 07-11-2007, 03:31 PM
phantomcow2 is on a distinguished road
Milling G-7 Garolite
So I have to machine several pieces of grade G7 garolite, to make a fixture. This stuff seems pretty nasty, at least when I first hit it with a drill. Are there any guidelines I should follow while milling this stuff?
Old 07-12-2007, 06:21 AM
pcschwenke is on a distinguished road
Use carbide endmills and have a vacuum running to remove chips. G7 machines very easy compared to G11! Be sure to check endmill from time to time and keep it sharp. The Glass tends to round edges after continous use. Do not have the RPM's very high, use Steel type settings.
Paul
FR4/Garolite question pixpop Composites, Exotic Metals etc 2 06-21-2007 09:35 AM
3D IH Milling wildcat Industrial Hobbies (Support forum) 30 03-09-2007 05:32 PM
PCB milling FabCNC General Metalwork Discussion 5 05-24-2005 07:44 PM
Need help for CNC milling set up a00509265 Machine Problems, Solutions , Wireless DNC, serial port 1 01-22-2005 10:07 PM
New to milling Marlboro Benchtop Machines 3 08-23-2004 12:37 PM
