Old 07-10-2007, 02:09 PM
Crashmaster's Avatar
Crashmaster is on a distinguished road
Turning Delrin
I will be turning Delrin to make plugs to tubes. I was wondering if anybody out there had a recommendation of if coolant was needed. I was thinking it would not be necessary but a guy at my shop said delrin can were your inserts faster than some metals. Also, speed/feed recommendation would be appreciated. Thanks.
Old 07-10-2007, 02:15 PM
neilw20's Avatar
neilw20 is on a distinguished road
Cool wearing..
HSS gets well poliished and loses its edge REALLY QUICK. Solid carbide or similar only practical option for quantity. You can machine it faster with coolant. Try inserts that are meant for aluminum. Lots of top rake is good.
Old 07-10-2007, 02:23 PM
Black Delrin is very abrasive and will wear HSS very rapidly but carbide does last fairly well. Try to get micrograin carbide so you have the sharpest cutting edge possible. Delrin likes a nice sharp tool with little or no top rake, but avoid negative rake tooling. Speed and feed can be like brass or a bit slower than aluminum. Coolant is a good idea to keep things cool, Delrin will melt on the cutter at high speeds. For drilling use plenty of coolant, a new drill and peck frequently to get the chips out. For tapping watch out for chips wrapping around the tap and getting carried into the next hole, also new tap.
Old 07-10-2007, 02:25 PM
Once again Geof, I appreciate the quick answer.
Delrin or HDPE, which did you use? Glidergider DIY-CNC Router Table Machines 20 07-22-2010 08:14 PM
Delrin patriotswan General Metalwork Discussion 5 03-29-2007 09:04 PM
Turning smaller diameter delrin? conceptmachinin General Material Machining Solutions 29 03-08-2007 02:02 PM
Turning Delrin CNCadmin Glass, Plastic and Stone 3 11-15-2006 05:32 AM
Need help with Delrin Marc DIY-CNC Router Table Machines 9 05-26-2005 12:32 PM
