Old 07-09-2007, 08:41 AM
pbunnstf is on a distinguished road
Cutting hardened Thompson Rail.
I have a 25" length of hardened pre-drilled 1/2 " Thompson rail that I need to cut in half.
Can someone suggest what wou d be the best method? I have a small metal cutting bandsaw. Can I scribe through the hardened outside with a dremel and then cut with the saw?
Thanks for any help.
Old 07-09-2007, 09:53 AM
You got it. Grind thru the case and then you should be able to machine it. Or use an abrasive edge saw blade.
DZASTR
Old 07-09-2007, 10:05 AM
Thanks. I thought that would probably work but before ruining a shaft, I wanted some good advise.
Old 07-09-2007, 10:26 AM
Mcgyver is on a distinguished road
or use a hack saw after you get through the case - why risk a bandsaw blade if you didn't get all the hard stuff?
Old 07-09-2007, 12:40 PM
Mueller is on a distinguished road
I had to cut a bunch of this stuff in 25mm diameter, I used my abrasive cutoff saw as well, at least for me, the key thing was to slowly rotate the part once you get past the hardened area (you can feel/hear it)
Old 07-09-2007, 07:19 PM
NEATman is on a distinguished road
Where I work is a Thomson "cut center" and we cut and distribute thomson shafting to the northern US. The shafting is cut with an abrasive wheel and flood coolant. The ends are then ground on a belt sanding wheel. The 1/2" shafting will most likely be hardned to a depth of .06-.09". If you are cutting with a non-cooled abrasive wheel, take your time and don't overheat the part.
NEATman
Need Help for Thompson Grinder hanpeidong General Metal Working Machines 0 05-24-2007 09:21 AM
Thompson Rod T Supports?? fritts Linear and Rotary Motion 1 04-20-2006 06:25 AM
Are these Thompson bearings any good? WarrenW Linear and Rotary Motion 4 11-08-2005 11:17 PM
thompson shaft and bearings corrie DIY-CNC Router Table Machines 5 07-01-2004 08:32 PM
thk versus thompson newguy DIY-CNC Router Table Machines 5 04-19-2004 12:45 PM
