For anybody that can help me. I just recently made a part that had six holes that had to be tapped @ 1/4-18 NPT. I did it in the mill, and they looked great. But when I put the fittings in, they seemed to go in a little bit to far for my comfort. When I am tapping pipe thread like that on the mill, is there a rule that says you should not run the tap down to %100 percent of the threads? Maybe I should be only be tapping down to about %75 of the tap. These are not being tapped for pipe nipples, but brass straight fittings, and 90 degree fittings. Any help would be appreciated. Tim Barry www.baywatchtowers.com |
| You can probably find a rule in The Machinery Handbook and you can probably buy gauges for tapping threads. Generally with 1/4" NPT I have the part available that will fit in the thread and tap deep enough to get around 5 thread engaged before it is too tight to turn by hand. Often this is less than 75% of full depth on the tap. If you are doing these parts for a customer and they are expected to be interchangeable with parts from other sources I think it is a case of you must get the gauges and do things according to standards.
| Geof, Thanks for the input. I did have the parts on hand. Just didn't think about it until after they were tapped. I think I will search for a tap gauge. That would probably be best. Thanks, TB www.baywatchtowers.com |
| Thread mill in XR2 | DSL PWR | OneCNC | 2 | 01-16-2007 12:40 AM |
| emt conduit, galvanized pipe or black pipe? | JohnG | DIY-CNC Router Table Machines | 5 | 05-21-2006 08:24 PM |
| Pipe Thread | harley88 | Haas Mills | 2 | 11-29-2005 10:43 AM |
| NPT pipe thread | positiverake | General Metalwork Discussion | 2 | 10-28-2005 09:59 PM |
| tapping head vs hand/cordless tapping machine.... | InspirationTool | General Metal Working Machines | 6 | 09-12-2005 08:10 PM |
