Old 07-03-2007, 09:34 AM
pbunnstf is on a distinguished road
Stupid question on turning
I have had a small lathe for a year or so and have learned by trial and error.
This is likely a dumb question on measuring - suppose that you are turning down an ACME screw from 1/2" to 3/8" to fit a coupler.
How do you get a real good accurate measurement of the final 3/8".
I have a set of digital calipers that I have used but how is it done with high precision?
Old 07-03-2007, 11:59 AM
Shotout's Avatar
Shotout is on a distinguished road
I assume you mean turning down the the end of the screw to a shaft, not turning it down and re-threading it. If so to measure the OD use a quality micrometer 0-1in range and for length use a dial indicator with enough travel to accomidate the length, touch off and lightly face the end of the part, set the indicator to 0 and turn the length back using the indicator to measure the length. I like to leave a small finish allowance at a shoulder to face after the last longitudal cut to give a nice clean shoulder.
If you are re-threading it use the above to turn the OD determined by the class fit, calculate you minor dia and cut the thread, before finishing use a thread micrometer to assure that your crossfeed indicated depth is true and your thread is to tolerance. Ex your calculations say infeed by .008 to finish the thread, your mic reading may say infeed by .011, use the mic reading for an accurate precision thread.
A lot of this information is avilable in detail in the Machinery's Handbook, not just classes but actual procedures on how to cut a thread, measure a thread etc. If you are going to be doing precision work it might be worth the investment.
Scott
Suppose you were an idiot and suppose you were a member of Congress. But I repeat myself.
Mark Twain
Old 07-03-2007, 01:46 PM
Thanks Scott. Set up and measurement seems to be the hardest thing to get info on.
Old 07-03-2007, 02:23 PM
Shotout's Avatar
Glad it helped. Lots of people on here have helped me so...
You might want to check out some machine tool tech text books. I still refering back to my school text, even a year after graduation, on occasion. Sometimes it is quicker than the handbook, sometimes it is just more plain in language. Since you said you were learning along these types of books are an excellent source of info, not overly technical but they explain the hows and whys of machine work. Amazon.com has a more recent edition of my school text Machine Tool Technology for 98.00 new down to 21.95 used. If you think it would be helpful it is a thought.
Scott
Mark Twain
Old 07-03-2007, 02:27 PM
I just ordered four books from Amazon. Machine Tool Technology may be another one. I'll check it out
Thanks again.
Old 08-11-2007, 11:16 AM
mhtom is on a distinguished road
Smile
Calibers are great for rough work or ballpark measuring. Nothing beats a micrometer. Same cost but more accurate.
Old 08-11-2007, 10:19 PM
yoopertool is on a distinguished road
try using an optical comparitor or a toolmakers scope. Google either of those and you will see what I mean. With those you can measure any dimension on the thread. Good luck!
Old 08-20-2007, 11:15 AM
JROM is on a distinguished road
Were I come from calipers are called very nears! Get yourself a good set of mikes. You can do .0001 with a good mike. (and a little practice)
Be carefull what you wish for, you might get it.
Another stupid question? t305100 General CNC (Mill and Lathe) Control Software (NC) 15 09-03-2006 08:01 PM
Stupid Question CNCRob CNCzone Club House 2 09-04-2005 01:42 PM
stupid question boomer187um Autodesk Software (Autocad, Inventor etc) 3 08-29-2005 04:16 PM
New here, 1st stupid question! FXRocket General Metal Working Machines 4 11-03-2004 09:04 PM
STupid newbie question..... sentra52 DIY-CNC Router Table Machines 2 03-04-2004 11:20 PM
