| I run a VMC and would like to connect a Unist or Trico system that uses vegetable oil for face milling, near dry milling with coated carbide endmills and possibly tapping. It's between $450 and $600 for a system, so I'd like to get it right the first time. I have an extra M code relay I can use for turning the system on and off. I've seen Haas machines using a hollow rod Bimba type cylinder that extends a few inches when activated, right up to the cutter. I'd like to hear people's experiences with these systems. I've heard of some pretty impressive results and it's always cleaner than flood coolant. I don't have coolant through, so drilling will always be with flood coolant. Any alternatives to the $70-80/gallon I see for the vegetable based cutting oil would be cool too. Also, tapping applications in detail would be appreciated. Thanks guys. Dave Last edited by davereagan; 07-03-2007 at 12:55 AM. Reason: no response |
| I've had nothing but good results from the Unist system. You can use these systems with rotary union adapters (George Whalley?) In fact, that's how I started using those systems. IMHO, it's the pressurized air that does the work. The oil provides the lubrication and you really need very little of that. The Vegetable oils stand up well to heat. Think of "PAM" in a frying pan or Castor oil in racing engines, both are veggie oil. Dick Z
__________________ DZASTR |
| Brush finishing aluminum tubing in quantity | mxtras | Mass finishing equipment/media/stratigies | 17 | 01-02-2008 10:37 PM |
| small quantity plastic source? | zcases | Glass, Plastic and Stone | 7 | 01-02-2007 11:20 AM |
| where to get small quantity of material? | pp-TG | General Metalwork Discussion | 3 | 12-08-2006 07:56 AM |
| Looking for small, simple, manual lathe work, any quantity | sanddrag | Employment Opportunity | 2 | 08-01-2006 08:31 PM |
| Lubricant | joecnc2006 | Mechanical Calculations/Engineering Design | 0 | 11-26-2005 01:35 AM |
