I'm going to order endmills for aluminum cutting and facing and looking for a good finish. So far with a used unknown HSS 2-flute bit I can get decent results in 6061-T6 (which will be the material I'd use). My mill is a CNC'd HF geared head benchtop mill (a bit bigger than an X3), 1500rpm max. So far I've figured out, learned, deduced, and decided I need 2-flute, un-coated HSS, high-helix angle, centercutting. I'll probably get roughers and finishing endmills. But how do I know the difference between one manufacturer's endmills and the other? Is there any other spec I should be looking for, or enquiring about? In other words, should I get the on-sale ones at Enco or Discount Tools, or should I be looking at Seco, Kennametal, Dataflute etc? I know not to get the HF ones. And how would I know that they do what they say? I'm not a production shop, but will be doing my prototypes and one-offs for customers so it'll be very low volume, so not sure that the big names would even want to speak with me. ![]() Finally, what sources are good for these endmills? I know of Enco, MSC, Discount Tools and American carbide, but haven't found some specific types yet (such as bevel-cutting bits). Any info appreciated. Thanks, -Neil. |
| If you look on the MSC website under Single Endmills they have a sub section on Alum cutting, all the tools in it are rated by the manufacture for cutting alum. Use the drop down menus to select length and dia etc to narrow your selections and sort by price. Beveled cuts, if you mean chamfers search drill mills. All sizes of 90deg (cuts 45deg chamf) cutters there. I use these a lot to chamfer holes just to clean the edges or before tapping to give a better tapped hole, chamfer to print spec as well as chamfers down of .005 along the contours of a part just to break edges for a better finished part. A search for chamfer will bring up chamfering tools of various degrees and dia as well. Every part we make (excluding countersinking screws) call for 45deg chamfers when one is called for so I prefer drill mills over regular chamfering tools and even use them as spotting drills sometimes to minimize the number of tools I have in a program. Hope this helps Scott
__________________ Suppose you were an idiot and suppose you were a member of Congress. But I repeat myself. Mark Twain |
| Check out this link for Minicut:http://www.minicut.com/index.html |
| I've spoken to the technical help people at a milling bit company and asked them about milling aluminium. What they told me was that aluminium is quite a sticky metal, and tends to weld itself to the tool, creating a built-up edge. This effectively makes the tool behave as if it were blunt. Some tools are coated with TiAlN, which reduces the amount of welding which happens, and lets the tool last much longer than an uncoated one. One of the tools we use for alu is a 4mm diametre, 4 flute, TiAlN coated, 45 degree rake angle. It cuts well at 5000prm and 0.006mm feed per tooth. hugo |
| We mill a decent amount of aluminum. I've found the really cheap endmills don't work so well (the Chinese import junk from Grizzly or Harbor Freight). They are sort of OK in a pinch, but they dont last long and I think the tool geometry isnt very accurately ground, because finish sucks. Then you have the regular mills you get at MSC and McMaster. Thats what we use for 99% of our cutting. Solid carbide works better than HSS, and TiAlN (I believe it's that - the gold one) helps prevent gumming of the bit and chips welding to the end. You're limited on RPM's and feed with a smaller machine, but I can tell you we experienced a WORLD of difference between crappy mills and decent ones from MSC, both on a Grizzly mill-drill and a Leadwell V-40 40x20 VMC and a Leadwell MCV-0 mini-VMC. You probably want to use a 2-flute for slotting and most pocketing, but for a really nice finish, we find a high-helix 4-flute (or even higher, maybe 6 flute) with as much RPM and a real light cut (maybe a few thou) produces very nice results. You can sort of see the toolmarks, but you can barely feel them, nice crisp corners with no burrs, etc. The grade of Al matters too... if it's from a known supplier it should be fine, but I've sometimes found offcuts that werent marked that didnt machine very well. I suspect they were sold as 6061 but probably were another alloy. |
Definitely get the roughers; I forget what they call them...gash toothed or something. When you are limited in speed and power they make the world of difference in removing metal quickly. And regardless of your cutter type for a good surface finish some form of cutting fluid is essential. A readily available and cheap alternative to regular cutting fluids is ATF automatic transmission fluid. Paint it along the cut line or have a little sprayer can, you don't need much. Or you can go with regular cutting fluids and a mister system but that needs an air supply.
| We cut tons of 5052 alum sheet which tends to be gummier than 6061. We have had great luck with single flute aluminum cutting carbide router bits from Onsrud. The single flute has plenty of chip clearance. We run them fast. 3/16 at 12,000 to 15,000 rpm, 3/8" at 5,000 to 6,000 rpm. We run these on our router, in our VMC and on CNC-Knee mills. Boelube is a great coolant lubricant for this work if you are spray misting. Brush-on we've had good success with kerosene and Tap-Majic for Aluminum. For more conventional work we find that two flute HSS aluminum grind endmills work good. On the east coast US, Travers Tool Company is usually more competitive price wise than MSC for what we buy and they have next day delivery too. John |
| Wow, someone woke up this thread Timely-ish though, as I finally got around to ordering the end-mills on Monday (I had some setbacks with re-building my CNC controller) and they'll be here by Friday. I got some high-helix HSS 2-flute cutters, some ball end mills, some drill-mills, and a rougher. For now, I went with some enco parts, but did n't see anything I thought would be great for for finishing from them. I'll probably be trying out a Hanita 2-flute 1/2" bright HSS end mill from MSC, or perhaps some other cutter from a different source. I do order regularly from McMaster (other things), but have never checked out their end-mill selection. In my discussions with tool companies (manufacturers and outlets who know end-mills, rather than just Enco etc who seem to be catalog houses), research, and some experimentation, I found out some interesting things... - Coatings extend tool life, rather than create a better finish. Apparently a coating results in some rounding at the cutting edge rather than uncoated which can be sharpened to a very sharp edge. This is the first I've heard about that TiAlN though. - Coolant/lube is a must with aluminum. I'm currently using WD-40 (and plently of it), which most say is decent, but I'll find something more optimal (such as a misting or drip system) later. - Aluminum grade is critical. See my other post here. I picked up some 2024 and 7075, but have not yet tried those. - High spindle speeds is a must. Since my mill will only do 1500rpm, the recommendation was to cut very slowly. I got better results with a light finishing pass at 2ipm rather than at 10ipm (spindle at 1500 rpm in both cases). I am working on adding a VFD/motor change in the future. - A larger diameter cutting bit will increase surface speed of the cutting bit. - I got better results cutting a "light" finishing pass (maybe 10-20 thou) than I did cutting a "super-light" cutting pass (such as a few thou). Don't know if the latter is small enough that the backlash/flex causes the mill to "go around" the material that cut through it. That's the theory running thru my newbie head right now. Note that my mill is sturdier than the X2, X3 etc. - Backlash will cause finish issues. I'm working on doing a ballscrew conversion in the near future. - Many suggested that 3-flute high-helix will work just as well as 2-flute, but everyone felt that 4-flute would be worse. - Best bang for the buck with my existing setup will be to use a rougher first, at a higher cut speed (say 20-30ipm), then finish at a few ipm. My thought is to remove as little material as possible for roughing so I'm going to try a 1/4" or 3/16" rougher. Then for finishing I'll use a 1/2" or larger 2-flute HSS high-helix. I'll post results when I get some. Cheers, -Neil. |
#10
Good luck! Keep us posted. I'll post results when I get some. Cheers, -Neil.[/QUOTE] |
#11
| First you can anodize 7075 you just have to tell them the alloy. next forget HSS, carbide is the way to go. It is more money up front but your finished parts will be much better with carbide. Try to find a Garr dealer in your area. These are very high quality cutters with good prices. I cut alot of 6061t6 and I use three flute 50 deg. helix carbide endmills uncoated. If you can run at about 7,000 rpms 100 IPM with a 3/8 or 1/2 dia cutter. Also use cutting fluid, alight cutting oil will work fine I've used kerosene (Colman fuel) or any good water based coolent. These cutters work like the desplays you see at the trade shows. Give it a try |
#12
| You can try the Garr VHX roughers. They don't mention using them in ally, But I'm running them @ 10,000 RPM and 200+ inches a minute @ roughly .25" deep. Garr 242M seris is the 2-flute version for aluminum. Works like a hot damn. OSG makes some nice aluminum mills too.
__________________ "It's only funny until some one get's hurt, and then it's just hilarious!!" Mike Patton - Faith No More Ricochet |
| Endmill selection | sdantonio | Wood Working Tooling | 1 | 04-07-2007 10:44 PM |
| Please help me identify AMS endmill | johnbirch | General Metalwork Discussion | 0 | 04-07-2007 03:22 PM |
| Need endmill advice for x1 | simpleton | Benchtop Machines | 14 | 11-11-2006 06:44 PM |
| Endmill bit and holder. | ihkim | General Metalwork Discussion | 0 | 07-26-2005 01:38 PM |
| Endmill runout | dberndt | General Metalwork Discussion | 14 | 01-27-2005 11:26 PM |
