View Poll Results: how effective is burnishing to create good surface finish and size
burnishing is useful for good finish 4 66.67%
burnishing is useful for maintaining dimensions 4 66.67%
Multiple Choice Poll. Voters: 6. You may not vote on this poll
Old 06-30-2007, 03:52 AM
soszi1950 is on a distinguished road
Smile burnishing roller and diamond help needed
HI
I am machining some large PB1 bronze bearings typical dimension 450mm long 350mm bore 400mm outside diameter.
I have purchsed inside and outside burnishing tooling and would to know if anyone can help with
(A) feeds and speeds
(B) amount of material required to be left on the surface to enable the burnishing tool to provide a good finish and also to bring to final size.
thanks
soszi1950
cape town
Old 07-05-2007, 06:26 PM
soszi1950, You might want to check out the Cogsdill Tool site
DZASTR
Old 08-11-2007, 11:09 AM
mhtom is on a distinguished road
Smile
Check out cogsdill tools they work great. Rule of thumb is 0.0008 of material for that kind of work. Any more and it won't work.
Roller hold down Max Richards Work Fixtures and Hold-Down Solutions 0 06-06-2007 11:30 PM
My new roller Scratch Bending, Forging,Extrusion... 3 10-07-2006 08:30 AM
flat bottom roller burnishing tool qmas99 General Metalwork Discussion 3 09-27-2006 05:17 PM
diamond pin fpworks General Metalwork Discussion 2 09-18-2006 11:52 AM
Roller Bearings Bruggles DIY-CNC Router Table Machines 14 07-17-2006 02:11 AM
