Old 06-20-2007, 07:50 AM
Cycle Start is on a distinguished road
chainsaw bar oil for way lube
Hello
Has anyone heard of using bar oil for way lube? If not what way lube would you use for a series 2 copy knee mill with turcite on the way surfaces?
Thanks in advance
Joe
Old 06-20-2007, 08:22 AM
Shotout's Avatar
Shotout is on a distinguished road
Originally Posted by Cycle Start View Post
Hello
Thanks in advance
Joe
Turcite (Ethylene-chlorotrifluoroethlyene [ECTFE]) is a self lubricated plastic grade TA is blue and TX is red. Are the ways meant to have external lubrication? We make parts for mechanical slides where oil contamination is a no no so I don't know what types of oil it is compatable with. What references I have say it is chemically resistant, but no more. You could call Boedecker Plastics, which is where we get it, and ask them what type of oils are compatable with the grade you have. Their numer is 1-800-444-3485.
Suppose you were an idiot and suppose you were a member of Congress. But I repeat myself.
Mark Twain
Old 06-20-2007, 09:03 AM
This is green in color. The mill has an automatic lube system on all of the ways. I do not know if it is turcite, but it is some type of anti-friction material.
Old 06-20-2007, 11:18 AM
Shotout's Avatar
The only material we work with that is green is oil impregnated nylon. Sorry I couldn't help.
Mark Twain
Old 06-20-2007, 12:23 PM
DareBee's Avatar
Monkeywrench Technician
DareBee is on a distinguished road
A waylube system SHOULD USE WAYLUBE.
Every oil supplier can get you a "Waylube 60" product.
This is the most common waylube and is used in every machine tool I have ever seen.
www.integratedmechanical.ca
Old 06-20-2007, 12:30 PM
Karl_T's Avatar
Karl_T is on a distinguished road
Hello
Thanks in advance
Joe
Chainsaw bar oil is way lube, just different name for different application. It cost more than way lube, at least if you by 5 gallon pails. I just use way lube in my chainsaw.
Karl
Old 06-20-2007, 01:18 PM
I have a sneaking suspicion that "chain oil" is like a 5 cent cigar. The oil equivelant of "floor sweepins' "
DZASTR
Old 06-20-2007, 07:46 PM
I think you are being too cynical . I think it is simply mineral oil with an additive to make it kinda 'sticky' so it doesn't run off of fling off easily.
On Turcite I would use plain mineral oil. Turcite is acetal based and I know acetal (Delrin is acetal) is not affected by plain oil but I don't know if it is affected by the additives in way oil or chain oil. With Turcite these additives are not needed anyway.
Old 06-20-2007, 07:57 PM
Gold Member
Adobe Machine is on a distinguished road
Usually, I would never get in this discussion..any lube is better than none, but the petro engineers have worked real hard to make an oil ( way lube) that will lube and "unstick"..chainsaw oil was disigned to stick to the chain to lube it..Way oil was designed for Machine Equipment to lubricate, but avoid "stickem"...If your ruinning an accurate CNC Machine, go with the manufactures reccomendations..( a way lube) a "Hobby" machine, just keep some kind of lube on the ways, always, and keep the ways clean.
Adobe (old as dirt)
Old 06-21-2007, 11:56 AM
A cheap cigar with "stickum' "?
DZASTR
Which way lube oil? WilliamD General Metal Working Machines 4 02-26-2007 08:46 PM
Lube monte55 Linear and Rotary Motion 2 09-17-2006 04:42 PM
Tap Lube Gitanes General Metalwork Discussion 5 11-26-2005 07:45 AM
My first lathe! What lube to use? gdl357 Mini Lathe 2 08-18-2004 11:06 PM
I need lube! CNCadmin General Metal Working Machines 11 06-01-2003 08:25 AM
