Old 06-18-2007, 02:42 PM
jeffo2001 is on a distinguished road
Red face How drill/bore larger pockets in aluminum???
Hi all,
I need to bore a few larger dia holes in aluminum on my mill. (1.024" dia and
0.828" dia.) These will be pockets for bearings so they will need to be
fairly accurate.
I am planning on making a couple "counterbores" with
these diameters to use to cut these holes. Does anyone have
any other ideas how I can drill or bore these holes using a small
benchtop mill? The holes only need to be about 1/4" deep or so.
I really don't want to spend the time making special counterbores
for only two holes.
Any advice would be greatly appreciated....
Thanks !!!!
Jeff
Old 06-18-2007, 02:47 PM
jc_eng is on a distinguished road
You should get the tolerance from your bearing manufacturer before making the holes. How are you getting your dimension?
Old 06-18-2007, 02:48 PM
wildcat is on a distinguished road
Do you not want to use a boring head because of the time needed to enlarge the hole?
Old 06-18-2007, 03:06 PM
Thanks for the replies guys. To answer your questions:
The dimensions for the holes are for a slip fit for the bearings I have.
I don't have a boring head available. I've never even used one on my
mill. I looked at a few on ebay but they were too large and too expensive.
Any reccommendations on where I might can look for a small boring head?
McMaster has a neat little adjustable counterbore but it's like $400.00.
Thanks again fellas,
Jeff
Old 06-18-2007, 03:49 PM
Just for example...
http://www.littlemachineshop.com/pro...1266&category=
Old 06-18-2007, 08:02 PM
The_Roadrunner's Avatar
The_Roadrunner is on a distinguished road
Originally Posted by wildcat View Post
Just for example...
That's a mighty low price. I'm not very fond of boring heads with only .001 graduations, but if that head is balanced it seems like a good deal.
Old 06-18-2007, 08:10 PM
Delcamfan is on a distinguished road
a cheap way to do this is just to snag up a piece of high speed......hand grind your cut edge and go to town.....for only two holes i think that this would be the most inexpensive way to do it
Old 06-18-2007, 08:59 PM
Thanks guys!!!!! I love this site......
Old 06-18-2007, 09:05 PM
I agree, that would be the most cost effective, and you should be able to hold the slip fit tolerance.
It would also be pretty easy to whip up those 2 tools on a surface grinder with a whirlygig and an endmill face sharpening fixture.
Old 06-21-2007, 02:05 AM
alexccmeister is on a distinguished road
I am doing a 38mm diameter pocket on a fairly small work piece. around 3" by 2" by 10mm thick aluminium. Here is the thread I just started on how to make a temporary rotary table.
http://www.cnczone.com/forums/showthread.php?t=39316
  #11   Ban this user!
Old 08-11-2007, 11:33 AM
mhtom is on a distinguished road
Smile
Why buy or make tools for special jobs. Doesn't your mill have circle-interpulating capabilities? If it does use it. Very accurately.
Old 08-11-2007, 02:21 PM
tobyaxis's Avatar
Moderator
tobyaxis is on a distinguished road
I believe this is a Manual Bench Top Mill.
Anyway you would be better off with the Boring Head because then you could Bore both large and small bores when ever you wanted. The investment is small when you compare it to buying different tools for different sized bores. This is of coarse if you plan on doing other projects.
Toby D.
"Imagination and Memory are but one thing, but for divers considerations have divers names"
Schwarzwald
www.refractotech.com
Spade Drill Does Work in Aluminum; Big Hole Boring on Drill Press. Geof General Metalwork Discussion 47 02-01-2008 01:32 PM
pockets raymond1 Haas Visual Quick Code 8 05-20-2007 06:59 AM
Open Pockets big_mak OneCNC 1 08-04-2006 11:45 AM
Eliminating Pockets robinsoncr Rhino 3D 4 06-27-2006 11:21 AM
G code for pockets . . . D2theIzzave G-Code Programing 3 06-22-2005 08:28 AM
