I am trying to m/c s/s 304 with a 4mm solid carbide slot drill .5mm deep full dia. of cutter but keep on chipping the corners using approx. 3000 rpm 350m/mm feedrate what can I do to improve this because this is getting expensive |
| A slot drill has 2 flutes. (UK terminology) Chipping means you are going too fast. See this chart for troubleshooting http://www.speedsandfeeds.com/PDF%20...cationtips.pdf I very strongly recomend coated cutters - TiAin They will not only outlast 10:1 but SFM can be increased 15 - 20%
There are two ways to go: Use a specially designed 3 flute solid carbide endmill with a 35 degree helix and a .2mm to a .5mm radius on the corners. run at 200SFM (4865 rpm) and a feed rate of .025mm per tooth. I would take about 1/2 the diameter for depth of cut. I would use TIALN COATING on the endmill and I would use an air blast to evacuate the chips. My customer called with a machining problem and I have to go and help him in some Titanium. So I will end this posting as I don't get paid for this. I do get paid to solve my customers' machining problems. |
| Inaccurate feedrate | alfalfa | CamSoft Products | 39 | 05-18-2007 09:35 AM |
| feedrate for contouring using v9? | rapid | Mastercam | 5 | 04-15-2007 08:37 AM |
| Yet another feedrate question | B. Ender | WoodWorking | 3 | 02-23-2007 12:12 PM |
| Feedrate issues with v20? | mikesos1 | BobCad-Cam | 3 | 07-06-2005 05:07 PM |
| Spindle speeds and feedrate cap | HuFlungDung | OneCNC | 11 | 07-05-2005 01:05 PM |
