Old 06-05-2007, 03:39 PM
Jeff-Birt's Avatar
Jeff-Birt is on a distinguished road
How to machine/grind a thin taper
Just had a friend stop by with an unusual request (for me anyhow). He needs to produce samples of steel (type TBD) approximatly 50mm X 150mm x 1mm, with the 1mm thickness tapering down to a point across the 150mm length (same taper both sides). My only thought was to surface grind it, which I do not have the equipment to do. Am I missing something obvious?
Thanks,
Old 06-06-2007, 06:05 AM
Zumba is on a distinguished road
Yup, grind em.
You'll pretty much be making knives.
How/what machine to shape a thin stainless plate to become a "half" egg shape ? Calico General Metalwork Discussion 5 03-24-2007 10:40 AM
surface grind gibs? phantomcow2 General Metal Working Machines 0 06-11-2006 08:10 PM
Grind my bearings? Oldmanandhistoy Linear and Rotary Motion 20 02-18-2006 08:53 AM
can anyone grind oblong punches on diameter? fastolds Employment Opportunity 4 12-16-2005 12:13 PM
CNC Router Taper Machine hadjcues DIY-CNC Router Table Machines 8 03-23-2005 06:02 PM
