Old 05-27-2007, 11:02 PM
FBJR is on a distinguished road
Setup Help, CNC refit
Just my second post here guys but here is what I have and what I have done.
I have owned 1 Mill and several Lathes before now and know machining basics. (Smithy Mill, sherline to Jet 1340 lathe) Really just enough to get me into and out of trouble
I had a nice Wabeco CNC mill all setup but had a fire which distroyed the Wabeco and the 1340 Lathe. I have now refit the Wabeco 1210E (less cnc) and pickuped a nice Emco Maximat in the meantime. I also picked up a Speedway 7x12 and a HF Mini Drill/Mill (Sieg X1?)
I need to setup the complete CNC side of the Mill now. I have the stepers, but that is it. I plan on using it for one-of parts really, but may do small runs since I do alot of RC Aircraft too.
After reading hundreds of posts here and other forums I am still unsure of which way to go. I need controllers/PS and all the wiring still and have looked at few links here, but still confused.
I had ONECNC before, but never got to use it. I did like the options and upgrades but don't think it is in my price range from recent posts now.
Suggestions to retailers, threads and complete setups are welcome. I really need to understand the setup from A to B.
Thanks in Advance
JR
Old 08-11-2007, 01:27 PM
mhtom is on a distinguished road
You might try contacting Fagor. They have retrofit and conversion kits and they will walk you through it.
Wire EDM refit control Karl_T CamSoft Products 5 09-23-2010 09:53 AM
Bridgeport boss5 refit paulsoncd1@juno General Metal Working Machines 3 01-16-2007 06:46 PM
What is your setup? dolanosa CNC Wire Foam Cutter Machines 5 10-09-2005 03:00 AM
Setup ACME General Metal Working Machines 0 09-07-2004 10:37 AM
Anyone know anything about this setup? efreak DIY-CNC Router Table Machines 1 08-29-2004 01:27 AM
