Old 05-16-2007, 04:02 PM
Crashmaster's Avatar
Crashmaster is on a distinguished road
Coolant or No Coolant when turning....
Is there ever an instance when flooding coolant can become counter productive when machining a part? Our shop uses mainly Steel, Stainless and Aluminum and
sometimes Delrin. Any thoughts?
Old 05-17-2007, 07:08 AM
HIRAH is on a distinguished road
depends on the material, insert and coating. turning steels with a tialn coated insert and coolant can introduce thermal fracturing of the coating.
kind of like throwing boiling water on a block of ice.
Old 05-18-2007, 03:04 AM
eject_21 is on a distinguished road
I dont use coolant during interrupted cuts. But always use it for non interrupted cuts. 347 ss, 321 ss, inco, Ti, We use Tialn coated inserts 95% of the time.
Old 05-20-2007, 02:20 AM
Mazaholic's Avatar
Mazaholic is on a distinguished road
I've never used coolant when using ceramics while turning case hardened chrome.
The heat is required for the ceramic insert to cut.
Looking for a better coolant? shawn General Metalwork Discussion 9 06-29-2009 11:13 AM
Coolant...Which and why? ajl6549 General Metalwork Discussion 15 12-08-2008 09:02 AM
programmable coolant pit202 Haas Mills 8 12-21-2006 10:51 AM
Best coolant machinist39 General Metalwork Discussion 15 05-13-2006 02:25 PM
COOLANT (what are you using?) carbidecraters General Metalwork Discussion 12 01-22-2006 01:31 AM
