Old 05-15-2007, 11:27 AM
Mitsui Seiki's Avatar
Mitsui Seiki is on a distinguished road
Thread milling problem.
Hi,guys.
I'm thread milling two M10 holes.
Why is the actual feed only 30% of what I have programmed?
Does param.1610 (Fanuc16m) and 6610( Fanuc15m) have anything to do with that?They are set to 30%.
//Stewen
Old 05-31-2007, 10:56 PM
silverfoxx03 is on a distinguished road
let me know what you got--I have a program that I can send you that works great or sources for another that will generate the codes for you
Old 08-11-2007, 01:12 PM
mhtom is on a distinguished road
Yes you solved your problem. You need to reset the paramiters higher if thats what you want.
Old 08-11-2007, 02:43 PM
I did that and it works fine now.
Thread Milling Don Clement Tormach PCNC 23 08-01-2011 07:48 PM
thread milling fourperf Fadal 13 03-10-2008 08:14 PM
Thread milling wjfiles General Metalwork Discussion 2 01-08-2007 05:13 PM
Thread milling, can anyone help jtrav General CAM Discussion 16 03-06-2006 03:25 PM
