Hi, Just found a Acu-rite 4-axis Turnmaster DRO for my lathe. How many scales is it worth getting? I thought about getting X Y and the toolpost slide and maybe seing if I could rig up a rotary encoder as the 4th axis to either give me a deg function on the toolpost slide (for turning tapers) or maybe fix it to the head stock and see if it would show rpm (speed). What would you normally use a 4th axis for an a lathe? I also toyed with the idea of fixing a scale to my tail stock so I could mesure the depth when drilling holes and tapping but it looks tricky to mount and would prevent me taking the tail stock off! Thanks. |
| Hi, I got by with one trav-a-dial on the lathe for years. I don't know what i would do without it, or do i want to improve it. When i drill a hole, i know its 10 turns per inch on the tailstock, when i tap, i put the tap in a drill chuck so it can slip when it bottoms. Most lathes have a vernier scale for the compound, that after 20 years of job shop work, has been good enough 4 me. After 20 years, i have NEVER used the taper attachment. I always thought if you don't buy it up front, you will never buy it, but from years of job shop work, i would go with 2 axis, no more. Buck Case, Spring Lake cnc llc |
| 4-axis diy router/lathe | skyten | Open Source CNC Machine Designs | 7 | 08-05-2008 01:52 PM |
| Lathe axis question | bjinatj | General Metal Working Machines | 4 | 05-14-2007 10:57 AM |
| 4th axis as a lathe... | WilliamD | DIY-CNC Router Table Machines | 5 | 02-03-2006 11:55 AM |
| 4th axis as lathe.. | WilliamD | General Metal Working Machines | 1 | 01-31-2006 08:59 PM |
| B-Axis Lathe Capabilities | John Field | Employment Opportunity | 1 | 09-14-2005 04:24 PM |
