I have cast a lead bulb for my sail boat and I need to mill the mating surfaces smooth. I was planning on using a jig and a router on a speed controller to slow the router down. What speed should I try to get the router down to? Thanks Sam |
Lead, as in what you shoot out of a shotgun? You will need coolant so it don't stick to your cutter, and even that may not work. I would use as low of RPM as you can get, and watch the cutter as i think it will load up right away and break, like when you cut aluminium without coolant. Pure lead? maybe just put it into a vise and sqush it into the shape you want. Maybe if you take your wifes iron, you can iron a smooth spot. Try that when she is not at home or wear ear plugs for safty. Normally you don't machine lead. Good Luck, Buck Case, Spring Lake cnc llc |
| Have you tried using a wood plane? Lead is soft enough to cut with a sharp knife; it just might be possible to plane it smooth.
| Surfacing question | frunple | BobCad-Cam | 16 | 07-11-2009 09:22 PM |
| newb has a question | Rookie | General CNC (Mill and Lathe) Control Software (NC) | 7 | 05-14-2007 08:21 PM |
| Excel-4 Fanuc 10-m control question (newb) | Robert Miller | General CNC (Mill and Lathe) Control Software (NC) | 2 | 11-13-2006 06:49 PM |
| simple surfacing question... | TurboME | Mastercam | 10 | 03-27-2006 08:30 PM |
| Newb question | csmith0413 | Stepper Motors and Drives | 3 | 10-03-2005 02:17 PM |
