Old 05-11-2007, 12:28 PM
abcdef is on a distinguished road
Smile Oval holes
Hi guys,
I am making holes of dia .261 ....on 1" aluminum pipe (.087 " thickness) ..
these are one wall holes ..so they want them neat and clean...
i used 1/4" E -MILL ...which is giving me oval holes... then someone told me to try this ...
divide the circle (hole ) into 2 and then made 2 different toolpaths for 2 half circles....
didn't get time to try it... but i wanna ask your inputs ?
thanks
Old 05-11-2007, 12:38 PM
sdopp is on a distinguished road
sounds like your spindle or gibbs are alittle loose
try a small ramp in and out
Skip
Old 08-11-2007, 01:46 PM
mhtom is on a distinguished road
Sounds like something is not tight. Work holding must be ridget and your spindle can't have any play in it.
Old 08-11-2007, 01:55 PM
dertsap's Avatar
Gold Member
dertsap is on a distinguished road
predrill with a 1/4" drill then drill the rest with a letter g drill
Old 08-11-2007, 02:13 PM
HuFlungDung's Avatar
Moderator
Which direction is the short axis of the oval?
Measure the hole ( in several directions) while the part is clamped. Then, measure it when it is released.
Consider that clamping the part in a vise may spring the part enough to cause a dimensional change after clamping distortion is removed.
Old 08-11-2007, 02:40 PM
tobyaxis's Avatar
Moderator
tobyaxis is on a distinguished road
Try using a 5C Collet Fixture to drill then Bore/Ream the I.D.'s The part will remain concentric and the finishes will benefit as well. Make sure you leave at least .015 for Reaming.
Toby D.
"Imagination and Memory are but one thing, but for divers considerations have divers names"
Schwarzwald
www.refractotech.com
offset holes harvard5 BobCad-Cam 5 04-26-2008 10:07 AM
Drilling holes wildcat General Metalwork Discussion 18 01-31-2007 10:38 PM
Holes? saturnnights SheetCam 2 02-22-2006 01:28 PM
Drilled Holes jonbanquer NCPlot G-Code editor / backplotter 6 05-25-2005 12:17 AM
holes Xeno PTC Pro/Manufacture 1 09-05-2003 07:11 PM
