| Hi all! As in the subject - I've got an access to a new lathe with mentioned control and I'm about to start learning how to deal with this machine/control and how to start creating my own parts. Of course I have to learn how to programm etc... What indications could you point me for the beginning?? I've already found some related links (link1, link2 and link3) but I'd like to get some more "practical" suggestions. Any reply would be much appreciated, thanks in advance |
| If you're new to G-code I would get familiar with the basic codes first (G1, G2, G0, G41, etc). Then concentrate on the machine/control specific codes. The best way to learn one machine is to read the manuals that came with it. Be ready though, the older Heidenhain controls were a bear to program and use.
__________________ I don't know much about anything but I know a little about everything.... |
| Greetings Grezeniua, I cannot speak directly about Heidenhain's CNC programming interface, but your question seems to be asking more about practical suggestions to begin learning CNC programming. I hope I am right . . . . First I took a look at your Links and right away Link1 looks super cool. What it will allow you to do (if I reviewed correctly) is map your G code moves on a test plot (the pilot) before the actual machine implements the resulting G code. This looks like a great way to start the learning process. Now, for what I would do as a first part scenario. What is it you wish to make? Something simple and basic is a great choice, but it should be something relevant to your goals. Try this: 1. Get a piece of Aluminium stock in your hands. Something close to desired shape. Put it right there on your desk. Make it an oversized piece too. Hopefully, its round too! 2. Imagine 10 to 50 mm held by the lathe chuck or collet. Here is good rule of thumb -- extend your stock max of 3x stock OD beyond your workholding device and have .3 of OD as minimum to grip. I like this for my own needs (it varies of course) and others will have theirs. You will develop your own intel as your experience grows. 3. Begin to see how you would initiate a ROUGHING sequence to FACE the front of the part to a desired length before a final finish face length. 4. Next make a similiar ROUGHING sequence to Turn the outside OD to a desired dimension. I go for something like .015 over final finished dimension on the part OD (oops --- .05mm!). Now for the Roughing of the face and OD you can select a specific Tool. I use a lot of VNMG/A tooling and have found a CNMG/A insert is great as the Roughing tool. 5. You have the basic part "Roughed" to shape. Something like .05mm over final finish dimension. 6. Select a new tool to begin your FINISH op. Follow the same paths as applied in the Roughing steps above but all of your dimensions should be set to create a finished machined part that matches the respective print dimensions you also have conveniently placed near your calipers and your stock. Ok -- how was that? You got some metal, you have a print and you have some way to measure and you have the heidenhain Pilot control to teach you the science of part profiling the CNC way. Here is some other bits to begin understanding: 1. Tool change clearance --- critical ! Start now to determine a safe area to make all tool changes free of your stock. This will be implemented with respective G code moves. I like X and Z moves in a single format. Like this: G01 X -2. ; part OD dimension times 2 (assume part OD is 1.0) Z 5. ; face of part = Z0. so Z goes to 5.0 in front of part face Now this is a safe place to index tool turret depending on your longest tool extension. 2. tool offsets. Setting tool offsets according your part's length beyond the workholding face this is the Z value from a "home" position. And then an X value based on tool touching the stock. Here many machines will do something unique. My machine for example has all X moves as Radius values. Your machine may or may not use this discipline. Find out right away and know it. Get these 2 principles understood quickly and you will be on your way. How have I done so far? I feel I am not helping too much, but maybe confusing you more . . . . I hope my rambling is right for your question!Would like to hear how the Pilot application works out for you. I have developed my own ritual for programming and can you show you a basic layout for my own G code applications if it will help. And others will have their individual rituals as well. As we say in my workplace --- "its all good" enjoy the learning, scott |
| Don't get discouraged if it all seems very confusing; it takes some time for things to soak into your brain. I had a few decades of manual experience but I bought a Haas lathe without ever having done any programming. It took me six weeks puzzling through the manual and pushing buttons on the machine before I had a successful program.
| OK! Thanks to all of you! I've just took part in a 2-days training for setting-up the machine and finally defining tools & programming... I think I'm able to build my own programm and to create a desired component ![]() Now I have more questions: could you advice me some PC programm to manage my NC programs/store them externally? Is there any free small application compatible with Heidenhain Manual Plus 4110? If so, then please send it to grzeniua@gmail.com. I have a network connector, serial (RS232) and USB? Do the cables need to be "crossed"? I suppose yes, but wanna be sure! How to configure the communication from Win2k system? If anyone has an experience exclusively in that control unit, please share your indications! Thanks in advance, Greg |
| Need help in deckel maho cnc machine Dear Sir, How r u? I have one CNC machine. Complete detail with model is given below: Machine Model: 64V Linear. Machine Maker: Deckel Maho Machine controller: Heidenhein iTNC530 In this machine I m facing one problem of I leak Led at power supply UV 123. That problem solved and now I have new alarm on the machine. When I ON the machine and after complete CNC system booting. Machine gave “relay ext. dc voltage missing”. When I ON the drives the all drives gave READY green LED. But after few seconds all drives off and machine at LCD screen gave alarm of C3B0 Motor X does not rotate or some times it’s gave C380 Motor X not controllable. Please give me the technical guidance to resolve my problem. Drive model is UM113. I have no any manual and electrical drawing. Hope you give me positive response. My email id is Subhani_engr1@yahoo.com Thanks |
| Help with Heidenhain 4110 Control | Eggo von Eggo | General CNC (Mill and Lathe) Control Software (NC) | 8 | 08-26-2007 05:47 PM |
| Need post for hied 4110 lathe | mick173 | Mach Software (ArtSoft software) | 0 | 02-23-2007 11:03 AM |
| Teach Yourself G-Code | Switcher | G-Code Programing | 1 | 11-20-2005 12:28 PM |
| Proper Use of TEACH? | squarewave | CamSoft Products | 3 | 06-24-2005 08:30 PM |
| Did you know you can Teach Onecnc? | HuFlungDung | OneCNC | 12 | 05-30-2003 09:08 PM |
