Old 04-21-2007, 04:46 PM
nophead00 is on a distinguished road
Question Spiral saw RPM
Hi, I just bought a 30,000RPM 600W spiral saw. It didn't come with any bits so I bought a 6mm spiral bit made by Bosch from the local DIY store. When I got it home I noticed it said on the back max 1000 RPM. Why such a big missmatch ?
If I attempt to cut 6mm aluminium sheet with it will bad things happen?
Old 04-21-2007, 07:04 PM
ger21's Avatar
Probably. Very quickly, too. Do you have the part number of that tool? It doesn't sound like a rotozip type tool if the max rpm is 1000.
Old 04-22-2007, 03:43 AM
The only numbers on the package are 2 609 255 304-000 and 55220309. I have tried Googling for these with no success. There is no description on the packaging either, just a picture of a drill being used to cut a slot between two holes in a sheet of what looks like thin metal.
The bit has a normal fluted drill for the first half inch and the rest is like a round file. What have I bought?
2D contouring with spiral Alan L Hypermill 0 12-30-2006 07:53 PM
Spiral pocket function LongRat SheetCam 2 12-28-2006 07:31 AM
The magical spiral paul3112 G-Code Programing 3 08-06-2006 09:46 AM
Spiral Cable source? Al_The_Man General Electronics Discussion 6 12-17-2005 09:39 AM
single flute or down spiral? barn5th General Material Machining Solutions 2 08-25-2005 04:55 PM
