Old 04-20-2007, 11:05 AM
abcdef is on a distinguished road
Need help in chamfering
I have 316 material plate of 1/2 " inch thick and 18" inch long.. plate have 3 holes of 4" inch each ..i need to chamfer (45 degree) those holes for about 0.400 "inch in depth ..
the problem is that the tool i am having has insert with cutting legth 0.275" inch ... i could think of doing it in 3D...
but i appriciate any idea other than that...
thank you
Old 04-20-2007, 11:53 AM
DareBee's Avatar
Monkeywrench Technician
DareBee is on a distinguished road
Use 2.5D circular interpolation and 2 or 3 stepdowns.
www.integratedmechanical.ca
Old 04-20-2007, 12:38 PM
keebler303 is on a distinguished road
you could also use a 1" drill mill, although not insertable, would get the job done.
http://www.use-enco.com/CGI/INSRIT?P...MPXNO=16720058
Old 04-20-2007, 09:12 PM
ctate2000 is on a distinguished road
Do it in steps. Calculate the change in diameter relative to the vertical move. Program two, three or x passes to achieve the desired chamfer. Simple trig.
Old 04-20-2007, 09:38 PM
You hardly even need to use trig. With 45degrees if you come up 0.1" then you go out 0.1":
Interpolate down to 0.4" with the tool tip at a radius of 2.1", then down to 0.3" with a radius of 2.2", then 0.2" with a radius of 2.3" and 0.1" with a radius of 2.4".
You could do it in fewer cuts but the tool width in contact would be larger and could possibly lead to chattering.
Old 04-21-2007, 03:06 PM
cb1 cb1 is offline
cb1 is on a distinguished road
i could make you a 1IN 4 fl. drill mill.
you will still need to interpolate. but the chamfer will be done i 1 pass
the 4 flutes should help elimate the chatter. i can make it carbide or hss
i can even pvd coat the tool to extend tool life.
Old 04-21-2007, 03:51 PM
tobyaxis's Avatar
Moderator
tobyaxis is on a distinguished road
Geof has a good idea with stepping down with a Mill Drill. You can get a 1/2 Diameter 4 Flute Carbide for around $47 dollars plus shipping and tax from Enco
http://www.use-enco.com/CGI/INPDFF?P...PARTPG=INLMK32
Cheers!!!!!!!!
Toby D.
"Imagination and Memory are but one thing, but for divers considerations have divers names"
Schwarzwald
www.refractotech.com
Old 04-23-2007, 08:57 AM
HIRAH is on a distinguished road
if you use an insertable cutter and you step up and over, make sure the 45° is right on the money. if not, you have mismatched lines in the chamfer.
Old 04-23-2007, 05:41 PM
tobyaxis's Avatar
Moderator
Well he could prevent this by Programming a .05 overlap in the Z axis
Cheers!!!!!
Toby D.
Schwarzwald
Old 04-23-2007, 06:04 PM
Cheers!!!!!
Sorry to disappoint you Mr Axis this would not work. If the cutting edge is not at 45 degrees then you have to use trig and calculate the stepover/depth ratio.
Old 04-23-2007, 09:59 PM
tobyaxis's Avatar
Moderator
Ooops!!!!! I was refering to a 45 Degree Mill Drill or Indexable Insert tool. Thanks for making it clear for others, LOL, I sometimes forget that I should include more information in replies to questions.
As a Note I have used CAD/CAM to create 45 Degree Chamfers with Ball End Mills. This is a good trick when you run short of Tool Pockets in the Magizine on a CNC Mill. Hence you have to have a Ball End Mill already in the machine and it's diameter has to be smaller than the hole being Chamfered.
Cheers!!!!!!!
Toby D.
Schwarzwald
  #12   Ban this user!
Old 04-23-2007, 10:44 PM
...As a Note I have used CAD/CAM to create 45 Degree Chamfers with Ball End Mills. This is a good trick when you run short of Tool Pockets in the Magizine on a CNC Mill. Hence you have to have a Ball End Mill already in the machine and it's diameter has to be smaller than the hole being Chamfered.
Cheers!!!!!!!
How long does it take to interpolate a chamfer this way? I would guess you can tolerate a stepover of about 0.005" so for a 0.4" deep chamfer that means at least 112 times around the circle (0.4 * 1.4 / 0.005 = 112). For the 3" holes mentioned in this thread your tool would have to travel around the 3" circle 112 times for a total distance of 3 * 3.14 * 112 = 1055inches. This is going to take a long time...or am I missing something?
Chamfering at diffrent heights? turboboy OneCNC 2 11-29-2006 06:29 PM
need help with auto radius and chamfering dry run G-Code Programing 1 01-30-2005 02:52 AM
chamfering Mortek General Metal Working Machines 4 02-06-2004 09:24 PM
