Old 04-18-2007, 07:02 AM
barnesy is on a distinguished road
small tapered slots
I have to m/c appox. 50 small slots with a .010 taper on the sides the slots are only .065 to .085 wide and .250 long. Any ideas on the best way to m/c these .We have thougth of may be sparking or wire cutting ? Any other ideas would be good
Old 04-18-2007, 07:16 AM
small slots
I forgot to say the mat. is s/s304 and .186 thick
Old 04-18-2007, 07:28 AM
jackson's Avatar
jackson is on a distinguished road
Well if you mill them you will have to use an endmill that is about .02 smaller than the slot its self make your first cut them come back and taper each side the desired amount
individual who perceives a solution and is willing to take command. Very often, that individual is crazy.
Old 04-21-2007, 05:14 PM
tobyaxis's Avatar
Moderator
tobyaxis is on a distinguished road
Depending on how long the slots are Wire EDM is the best way to do this. 304SS will work harden if an end mill dulls too much in the cut. If it is short you could have these Laser cut too.
Good luck with what you decide.
Cheers!!!!!!!!
Toby D.
"Imagination and Memory are but one thing, but for divers considerations have divers names"
Schwarzwald
www.refractotech.com
T slots in MDF?? JerryFlyGuy DIY-CNC Router Table Machines 26 03-10-2007 10:30 PM
Machined T-Slots? SpookyDad DIY-CNC Router Table Machines 6 07-16-2006 08:37 PM
Machine for making slots in SS tubing ngr1 General Metalwork Discussion 2 06-23-2006 01:00 PM
T-slots 4x8 - One side done samualt DIY-CNC Router Table Machines 13 06-07-2004 10:47 PM
Need help with T-Slots - Boring holes samualt DIY-CNC Router Table Machines 14 04-10-2004 10:39 PM
