Old 04-09-2007, 11:29 PM
grundig is on a distinguished road
Question precious metals speeds and feeds
Hey,
Can anyone suggest a source for speeds and feeds for machining precious metals (gold, platinum, silver, etc.)?
-Thanks
Old 04-10-2007, 07:26 AM
dfurlano is on a distinguished road
I wish there was an answer to this question but there as so many variables that it isn't practical to try and figure out. I machine silver, copper, and bronze and I use cutters that are .02 to .125 and I crank the speeds very high, use coolant and adjust the feed rate as I watch the chips (usually with magnifiers).
With these materials you need to be careful that the cut material does not reform and clog what you are cutting. Also breaking the cutters is always a concern. Hope some one has a better answer but I don't.
feeds and speeds JpBinc General Metalwork Discussion 4 10-03-2006 12:48 AM
feeds and speeds rchprks General Metalwork Discussion 2 07-17-2006 06:48 PM
Speeds for cutting metals relating to pulley size? ZipSnipe Mechanical Calculations/Engineering Design 2 06-15-2006 08:11 PM
feeds and speeds lito General Metalwork Discussion 4 03-14-2005 07:58 AM
feeds and speeds Mortek Hard and High Speed Machining 6 02-28-2004 03:59 AM
