| If you are talking about standard metalworking vertical machining centers then machine zero, also known as the machine home position, is as far to the right as possible, as far away from the operator as possible and as high as possible. This is for a machine with the X axis travelling across the position of the operator, the Y axis away from the operator and the Z axis up and down. With this convention -Z movement is downwards, -X movement is to the left and -Y is toward the operator. And now for the brain bending part...you have to pretend you are sitting on the table of the machine. Machine movement is defined as motion of the spindle relative to the table but on most VMCs it is the table that moves. |
| Lathe??? Okay. Actually I am competing with you for being an idiot; you did mention only Z and X .Z as far away from the chuck as possible, normally all the way to right, is machine zero. X as far away from the spindle centerline as possible is machine zero. Z- moves tool toward chuck. X- moves tool toward centerline. In this case always use the spindle centerline as the reference for X and the spindle nose (chuck) for Z. |
| Moving the table to the left and front puts the spindle at the home position, the back right hand corner of the table. When you look at it this way it does not matter whether you are on a moving table machine or a gantry machine. The home position is with Z up, normally at the tool change level, and above the right rear corner of the work area. |
#11
| No malice intended, Geof. I was literally LOL when I read your post, not because of anything you said, but because there are two types of machinists: Those that view positioning as the movement of the table & saddle, and those that view it as the movement of the tool. Almost like the cutter comp direction conundrum. |
#12
And what is the conundrum regarding cutter comp? |
| Dumb Question | elogicca | Mach Mill | 4 | 06-11-2006 03:28 PM |
| dumb? question: cutting MDF | bkukowski | WoodWorking | 28 | 05-03-2006 10:22 PM |
| Seriously dumb CAM question | sploo | General CAM Discussion | 9 | 03-09-2006 04:55 PM |
| -OK I'll be the first to ask some dumb question- | Ol'Dusty | 80/20, TSLOTS and other Aluminum Framing Systems | 0 | 11-11-2004 08:32 AM |
| dumb question | rob1215 | General Metal Working Machines | 4 | 06-24-2004 12:27 PM |
