Old 04-09-2007, 01:32 PM
nagjames is on a distinguished road
Covering shop floor
I’d like to cover my basement carpet with some tiles or laminate floor. Currently I have a small benchtop mill (MaxNC) which is fully enclosed so my carpet is not messed up. But I want to buy a bigger mill the X3-Syil conversion and I think for this kind of mill carpet is not appropriate and I want to cover it somehow. I cannot remove the carpet because I’m renting the townhome. I went to IKEA the other day and seen some nice plastic tiles for $3.5/square foot. The mill is about 250Kgs and will be enclosed ( I’m planning to build the enclosure myself). The area I need to cover is about 120 square foot. I welcome any suggestions.
Thanks,
James
Old 04-09-2007, 02:06 PM
Switcher's Avatar
Moderator
Switcher is on a distinguished road
Why not, just remove the carpet (I'm sure you have a slab under it.)?
Wouldn't it cost less, to hire someone to re-install the carpet when/If you move later on?
The landlord would never know.
Just put it back like it was when you moved in.
Old 04-09-2007, 02:28 PM
thkoutsidthebox's Avatar
thkoutsidthebox is on a distinguished road
$3.50/ft^2 Are you sure it wasn't per square meter, or at least per square yard? And they're not even ceramic tiles! $3.50 per square foot is one single piece of 12x12 inch plastic. You'd pay that for quite a nice ceramic tile. That's a crazy price. Just buy a few large plastic or rubber mats, but dont spend that much on plastic tiles. Is it just me??? How 'nice' exactly were these tiles? Are you looking for something basic to cover the carpet, or something 'nice' ? Buy a roll of linoleum maybe, would that be cheaper? To cover 120ft^2 of someone else's floor and probably break/lose/dump half the tiles when you move out seems like a bit of a waste of money.
Old 04-09-2007, 03:20 PM
Thanks for your advices. I'm really not comfortable removing the carpet.
Yes the IKEA ones look nice but it was a bit too expensive. The linoleum might be an option I'll check how much it would cost. I wanted something firm too but not willing to spend $500 on tiles.
Thanks again,
James
Old 04-10-2007, 11:31 PM
JEFFY is on a distinguished road
I had this same problem years ago when I rented also. I first went and got some heavy plastic drop cloths and cover the carpets and then I cover the carpet with some thin plywood fitted to go wall to wall. then I had some very heavy tape to do the seams. Worked great, no chips and easy to sweep clean. Best part was when I left the plywood was use in the new shop to make shelfs.(make sure the plastic wraps the outside edge at the wall so the plywood won't scuff the trim)
JEFFY
Shop Floor Paint HiTech CNCzone Club House 2 02-15-2006 11:55 PM
New shop-Floor?? bdrmachine General Metalwork Discussion 5 09-19-2005 01:41 PM
Shop Floor CNCadmin General CAM Discussion 2 01-13-2004 03:32 PM
Shop Floor CNCadmin General CAM Discussion 5 06-23-2003 08:19 AM
Win the new ExcaliburCNC shop floor. CNCadmin CNCzone Club House 11 05-10-2003 06:37 PM
