Old 04-07-2007, 09:24 AM
Newby2 is on a distinguished road
Red face 6" X 10tpi Lh Acme Id Thread
I have to machine a nut to fit a 6" machine shaft with a 10TPI left hand Acme thread.
Any thoughts? Thanks in advance.
Steve
Old 04-07-2007, 01:50 PM
skmetal7 is on a distinguished road
i have a though: that's fricken huge!!
good luck!!
Old 04-07-2007, 02:01 PM
dan dimock is on a distinguished road
No Help
Man, I have try to come up with a way to help, but sorry, no help here.
Good luck.
Dan
Old 04-07-2007, 03:06 PM
Gold Member
lerman is on a distinguished road
It really depends on what type of equipment you have.
The usual way to cut threads is on a lathe. http://internaltool.com has appropriate tooling.
As an alternative, you should be able to cut them on a CNC milling machine with either a single point tool or a thread mill.
Ken
Kenneth Lerman
55 Main Street
Newtown, CT 06470
Old 04-07-2007, 03:17 PM
For everyones information, this nut is used to retain the speed regulating wheel of a centerless grinder. The wheel diameter is about 12" diameter and is about 15" long.
I will be cutting this on a Jet 13" X 40" gear head lathe. I do have an ID thread kit that includes acme inserts.
Would one want to advance (or retract, depending on how you look at it) the tool at an angle, as with conventional threads, or advance the tool straight in?
Again, thanks!
Steve
Old 04-07-2007, 03:22 PM
With that size of lathe you may be better off advancing the tool at the thread half angle. Ten TPI acme at 6 inches diameter will give a good cutting load. What is the material? If it is something like 4140 you have a good challenge ahead of you.
Old 04-07-2007, 04:28 PM
Geof, the material is 1045. Wouldn't advancing the tool at the half angle using a form insert result in a root diameter that is to wide?
Steve
Old 04-07-2007, 04:50 PM
Steve
C1045 ugh, not much better than 4140.
Advancing at the half angle means the tool is cutting on the front and on one flank; the other flank of the tool is travelling parallel to the flank of the thread. Some people suggest going slightly less than half angle so this side takes a very slight skim cut producing a smoother surface.
Old 04-07-2007, 05:47 PM
Geof...Just got off the phone with my Dad, (80 years old) and he said the same thing, slightly less than half the angle.
I'll give it a try Monday on a scrap piece. Thanks for your advice and will let you know how it turns out. (or in in this case!)
Steve
Old 04-10-2007, 10:31 PM
The nut is done and installed with a fit and feel better than I expected. There were a couple of buggers on the threads of the shaft but a little lapping compound took care of that.
Thanks to Geof and my Dad. Boss is happy, I am happy, and all is well.
Steve
"Save Thread" Feature Wanted samualt Suggestions for the CNCzone.com site. 8 05-02-2010 03:20 PM
Acme Thread Geoff63 Australia, New Zealand Club house 7 02-19-2008 10:47 PM
Another " Moving a Tormach to a basement" Thread Scott_M Tormach PCNC 10 03-30-2007 10:08 AM
Acme Internal Thread 1 ½ - 0.250P-2.000L-ACME-2G-LH (8 START) Help pandiyan.innova CNCzone Club House 7 11-16-2006 05:47 AM
Thread not showing up in the "New Post" section Mr.Chips Forum Questions or Problems 1 10-23-2006 02:14 AM
