What's the best way to cut the spokes for a flywheel like the one here http://www.stirlingengines.org.uk/thermo/harrie.jpeg . The only way I can think of right now is mapping out the whole thing and then clamping the piece off center on a rotary table 5 times. Is there any other way? |
By the way you would need to clamp it on a rotary table at least 10 times doing it manually. |
| That's what I thought... but if you cut around 200 degrees or so (just a guess), then go back to zero, increase the diameter, go back down, and cut around 80-ish degrees, you'll cut the back and front of a spoke, since all the holes are moon-shaped. If you do that 5 times you'll cut all the pieces out... I might be wrong about that though, but isn't there an easier way to cut the spokes? |
| If you had a little rotary table mounted the correct distance off center on a larger rotary rable you would not need to keep reclamping. But you are doing this for a hobby. Surely the enjoyment is in the process as much as the end result. Looking for the easy way you are cheating yourself of the sense of satisfaction that comes from meeting a challenge . |
| On that note... maybe I could could machine a jig of sorts with 5 holes in a circle that I'd press fit the fly wheel onto. I'd drill 5 holes into the flywheel stock and countersink them almost all the way down, mill each spoke but not all the way down, just above the screws. Then, I could take out the screws and take down the remaining material on the lathe. |
| You can probably avoid the countersunk screws. Fully machine the flywheel on the lathe; this makes it a solid disc. Machine a disc which will be your rotary table fixture and have a recess that the flywheel OD fits. Drill your five locating holes in this disc and also drill a tap some holes around outside the recess. Clamp the flywheel into the recess with some large washers on bolts in the outer holes in the disc and then you can fully machine the spokes on the rotary. |
| Just center your rotary table on your mill table, use this as your zero reference point. Divide 360 by 5. Start at zero on your rotary table. Move your mill table the distance you want the rotary table to cut the curve, and at the end of your cut, return to your zero. Adjust your rotary table 72 degrees, and this becomes your new zero. Move your mill table the distance you want...repeat 5 times. No need to do multiple setups. Last edited by 307startup; 04-07-2007 at 01:41 AM. Reason: forgot something |
#10
| curved mouldings?? | Mike Boarman | General CAM Discussion | 1 | 01-12-2007 01:18 AM |
| help with g-codes for a 5 spoke wheel | Kevin Moore | General Metalwork Discussion | 0 | 10-11-2006 03:42 PM |
| Shifting the curved end toward one side | randyf1965 | SheetCam | 2 | 04-26-2006 06:51 PM |
| Which Software - Curved Surfaces | cwoodall | General CAM Discussion | 7 | 08-01-2005 01:37 PM |
| I spoke to ONECNC | CNCadmin | OneCNC | 8 | 03-12-2003 12:35 PM |
