Old 04-04-2007, 07:10 PM
mcarvey is on a distinguished road
Cut Off Tool Recommendations
I've never been really happy with my parting tool/cut off tool solution and am starting to look into insert type cut off tools. I usually cut aluminum and mild steel on a manual lathe.
For a while I have been using carbide tipped cut off tools (http://www.use-enco.com/CGI/INSRIT?PMAKA=383-7292 . They seem to do the job, but I have to resharpen them fairly regularly when the carbide chips, or replace them when it breaks off alltogether. At 11 dollars each, their price is reasonable, but I haven't been blown away by their performance in cutting steel. I am assuming this is due to the zero rake angle.
Has anyone used the cut off tool kit from Enco, and if so how does it perform? http://www.use-enco.com/CGI/INSRIT?PMAKA=422-2914 I don't mind spending the money if it does a great job but don't want to plunk down 140 bucks for something that isn't an improvement. What are you guys using for cut off tools/parting tools?
Thanks in Advance.
-Matt
Old 04-05-2007, 10:03 PM
BobWarfield's Avatar
BobWarfield is on a distinguished road
I've got the Aloris equivalent of what you've shown and like it a lot. I also use some pre-ground HSS tools that are real nice. Mini-reviews are on my page here:
http://www.thewarfields.com/cnccookb...tingCutoff.htm
Best,
BW
Old 04-06-2007, 12:49 AM
joecnc1234 is on a distinguished road
I use an iscar same design works great especially if you keep the chips clear.
joe
Old 04-07-2007, 10:27 AM
dandy is on a distinguished road
I agree with Joec iscar is the best c/o system i have used
Dand
Old 04-08-2007, 10:08 PM
tool_man is on a distinguished road
Not using insert type any longer
I used to use the insert type cutoff blades (Iscar) but,now I just use the parallel T-shape blades.Slow speeds and plenty of coolant and I am able to cleanly cut off about anything from mild steel to 304 stainless without any problem.Much cheaper too.They don't give those inserts away.
Old 04-09-2007, 03:37 AM
Tool_man are you running production. in a production environment you have to change tools. The cost of the insert justifies itself dramatically compared to resharpening and resetting a hss cutoff blade.
Old 04-23-2007, 10:17 AM
I just wanted to say that I tried out the cut off tool, and it is a noticeable improvement. Thanks for everyone's help!
-Matt
Tool recommendations? AndyL General Metal Working Machines 15 04-06-2007 02:53 PM
VFD recommendations? split63 General Metal Working Machines 13 05-27-2006 04:39 AM
Recommendations needed for tool holder originator General Metalwork Discussion 8 03-17-2006 01:23 PM
TIG recommendations? nervis1 Welding, Brazing, Soldering, Sealing 40 04-17-2005 12:50 AM
CAM Recommendations Benjamin General CAM Discussion 3 09-07-2003 10:32 PM
