Old 04-04-2007, 06:29 PM
dertsap's Avatar
Gold Member
dertsap is on a distinguished road
ingersol apkt recommendations ????
im wondering if anyone can recommend some ingersol apk inserts that can handle high speed high feed on mild steel , i m currently doing some jobs that i need to speed up , i'm gearing up to do some pretty high performance machining using a 1.5 turbo to start with , the inserts we are using are 1030 which in my opinion suck ,ive been looking at getting the 1040 inserts they have better resistence to wear heat and impact but i can definitely use some suggestions , i used to use sandvic at another place and everything was extremely fast , we used the 4030 inserts and they were pretty tolerant of what we put them thru ,i need something comparable , ive finally got thru to them (the boss ) that we could be running much faster ,and ive got the go ahead as long as the expense doesn t too far excede the price of the others
any ideas???
Old 04-04-2007, 08:42 PM
dertsap's Avatar
Gold Member
soooooo
ingersol loosing popularity ???
Iscar APKT IC328's and their knock offs carbidecraters CNC Tooling 3 06-28-2009 07:18 AM
Need some recommendations DragnsBane General Electronics Discussion 4 01-31-2007 03:11 PM
APKT inserts interchangable? beezerlm General Metalwork Discussion 1 10-27-2006 08:15 PM
VFD recommendations? split63 General Metal Working Machines 13 05-27-2006 04:39 AM
CAM Recommendations Benjamin General CAM Discussion 3 09-07-2003 10:32 PM
