Old 04-04-2007, 08:00 AM
Crashmaster's Avatar
Crashmaster is on a distinguished road
Question Metric Tap Speeds & Feeds
Hey guys, I need to tap a 10mm x 1.5, does anybody know the proper speed and feed for this? Thanks
Old 04-04-2007, 08:03 AM
DareBee's Avatar
Monkeywrench Technician
DareBee is on a distinguished road
Feed is 1.5mm per revolution.
Speed depends on your material, the type of tap you are using, blind hole/thru hole.
www.integratedmechanical.ca
Old 04-04-2007, 08:22 AM
I'm an idiot. Thanks. This is my first job that I have had to use metric and although it is proving to be much easier and is quite an adjustment.
Old 04-06-2007, 08:43 PM
dpuch is on a distinguished road
A tip for anyone using metric taps but programing using inch units. Use rpm's that are multiples of 254 For the above tap, 254rpm = 15ipm for rigid tapping. No rounding problems that way.
Old 09-14-2010, 11:20 AM
didzbartholome is on a distinguished road
hi there my name is didier and am busy also with my first tapping on a vertical machining centre. how did you work out the correct speed for the recommended feed?
Old 09-14-2010, 12:00 PM
Consider a 1.0mm pitch tap
25.4 mm per inch so 25.4x10 RPM = 1.0mmx10 IPM feed
254 RPM and 10 IPM
For a 0.75mm pitch tap
254 RPM = 7.5 IPM feed Which is fine, most controllers handle .x or even .xx feeds. Or just double both to 508 RPM and 15 IPM
for a 1.25mm pitch tap
254 RPM = 12.5 Same as above.
ect.
Old 09-14-2010, 12:54 PM
juergenwt is on a distinguished road
Crashmaster - If you are tapping metric thread I would think that the print is in metric. So why not bite the bullet and program in metric?
First job may be difficult at first but for other metric jobs you will be saving yourselves a lot of trouble. The worst thing you can do is keep converting. Believe me! You will screw up big time.
Old 09-23-2010, 08:24 AM
Wow, talk about reviving an old thread. Juergenwt; I will program a part in metric if that is what the print calls for. This part was the first time I had to actually tap something with a metric tap and wasn't quite sure how the feeds and speeds for a metric tap needed to be computed. After running this part and several like it, I actually prefer programming in metric now.
Old 03-29-2011, 09:11 PM
1armmachinist is on a distinguished road
I gotta use a M12x1.75 but I use a feed of ~ 10.0 and and speed of ...???
Example, 1/2-13 I program f10.0 and a speed of S130 ....
So with my metric I'm lost...
Old 03-30-2011, 08:35 AM
RPM 254 = 17.5 ipm. If you wanted a faster rpm just make sure you increase your feed proportionately. So if you doubled you RPM to 508 just make sure you double your feed too; 35 ipm. Does that make sense?
  #11   Ban this user!
Old 12-06-2011, 11:06 PM
quocthai714 is on a distinguished road
need to change metric to inches
M8X1.25 TAP
( mm X .03937) = inches.
1.25 mm x.03937= .0492125
then 800 rpm X .0492125 = F39.37.
Speeds & Feeds hector herrera Mastercam 1 02-20-2007 02:21 PM
feeds and speeds JpBinc General Metalwork Discussion 4 10-03-2006 12:48 AM
feeds and speeds rchprks General Metalwork Discussion 2 07-17-2006 06:48 PM
How to figure out Metric speeds and feeds etc kevh OneCNC 10 01-18-2006 02:36 PM
feeds and speeds Mortek Hard and High Speed Machining 6 02-28-2004 03:59 AM
