Old 03-31-2007, 12:07 PM
sencinia is on a distinguished road
Milling Macro
Would like a Fanuc type Macro for milling round bar flat in a rotary.
Need on that will increase Y axis start and end points on every pass as the Z axis increments down.
Anyone have such a macro?
Old 04-01-2007, 12:51 AM
psychomill is on a distinguished road
You need a macro just to mill flats??? Can you describe in better detail what you need and are trying to do? The question seems a little "strange" and its unclear what you're looking for....
It's just a part..... cutter still goes round and round....
Old 04-04-2007, 08:20 AM
Macro
We run a lot of parts that start out as round bar and end up square or rectangle. We run them mostly on a vertical mill using the rotary axis and machine all four sides. Would like a Macro where I could input variables
for the (1)Radius of the bar, (2)Dia. of the cutter, (3)Clearance for cutter, (4)Depth of cut for the cutter, (5)Start point in X,(6) End point in X,(7) final Z depth. It should then calculate each position in Y as the Z increments down. Because of the round bar, the start and end position will change with every pass made in Z.
Sure would be helpful to have such a macro.
Thanks Sonny
Macro Er. Bluesman Fanuc 3 04-05-2007 05:11 AM
Macro for milling round bar sencinia General Metalwork Discussion 0 03-31-2007 10:58 AM
Macro help fpworks Fadal 3 02-07-2007 04:13 PM
what is a macro? ljoe1969 Autodesk Software (Autocad, Inventor etc) 3 07-12-2006 08:12 AM
One More Macro ? 16I Bluesman General CNC (Mill and Lathe) Control Software (NC) 4 02-07-2006 05:06 PM
