Old 03-31-2007, 08:24 AM
kazam07 is on a distinguished road
cutting a radius
i'm trying to cut a radius on the front of a part. it looks like a tit on the front.
G1X-.015
G3X.0458Z.015R.025
G1X.114
X.196Z.056
I'm using tool noise comp but when i add the g41 it does even go anywhere close to the part. i'm using a .007 rad insert.
Old 03-31-2007, 11:47 AM
sencinia is on a distinguished road
Radius
Can I see the whole program?
What you are showing will error out on my CNC code anylyzer.
Old 03-31-2007, 12:13 PM
T1414(FINISH FACE)
G99G97G40
G0X.3Z0.0
G1X-.015
G3X.0458Z.015R.025
G1X.114
X.196Z.056
X.3
G28U0
(i also tried this & it didnt work)
T1414(FINISH FACE)
G99G97
G0X.3Z0.0
G1X-.015
G0W-.05X.05
G41X0Z0
G3X.0458Z.015R.025
G40G1X.114
X.196Z.056
X.3
G28U0
Thats all of the block that i can remember. i'm at home now. i made the post while at work. i know i have to use the G41 but when i but it in i get an alarm. it tells me that it cant complete the block but alarm book doesnt give me a fix. just tells me to edit the program. the only thing i can tell you now is that its got a .025 radius on the center of the face then it should radius into the face of the part then face up to .114 dia. then cut an angle at a 45 degree to a dia. of .196 which is past my .193 dim that is my thread major.
one other thing that i might have wrong. the direction that tool is pointing in the geometery page. the book indicates that it should be pointing to the 4 but the guy that programmed the machines before me had it as a 3 which in the book it shows 3 to be a backturn. i'm using a 35 degree front turn with a .007 radius. i dont know if this helps but it still dont work.
Old 04-02-2007, 08:26 PM
kolodok is on a distinguished road
try this
T1414(FINISH FACE)
G99G97G40
G0X.3Z0.0
G1X-.015
G3X.0458Z.015R.015 (you do have R.025)
G1X.114
X.196Z.056
X.3
G28U0
Old 04-02-2007, 09:46 PM
pp-TG is on a distinguished road
What size Radius are you trying to cut? And I take it the front of the part is not your Z0.? Your best bet is to program not using cutter comp it sucks on lathes....
Old 05-24-2007, 07:54 PM
cinomarra is on a distinguished road
turning radius
use g42 instead of g41 for external turning
Old 05-24-2007, 07:55 PM
turning radius
and make sure to have proper tool position in offset pagerobably t3
Old 05-25-2007, 08:35 PM
ctate2000 is on a distinguished road
cinomarra is correct. You need g42.
Old 05-25-2007, 09:06 PM
Mazaholic's Avatar
Mazaholic is on a distinguished road
Are you using a sub spindle?
Because it's rare that i see a lathe that is Z positive towards the chuck unless it's a sub chuck.
If your trying to go CCW then your gonna go the long way around.
How to Radius corners of a box. Xterrian G-Code Programing 16 06-23-2010 11:09 PM
Help with radius in mazatrol rstephen Mazak, Mitsubishi, Mazatrol 24 04-05-2007 07:30 AM
Radius in z axis? pp-TG G-Code Programing 4 01-24-2007 05:18 PM
Zero Radius Arc Xular Mach Mill 4 12-13-2006 09:10 PM
Circle instead of radius Prboz Mach Mill 7 10-01-2006 09:13 PM
