Old 03-28-2007, 09:38 AM
Crashmaster's Avatar
Crashmaster is on a distinguished road
Minimizing "Tits" on Lathe
Does anyone have any suggestions for how to minimize "tits" that form when cutting off stock on a lathe. Mine are around .055" in diameter. Is this just something that has to be dealt with?
Old 03-28-2007, 10:16 AM
CountZero is on a distinguished road
Sounds like you need to raise your tool up about 0.055"/2.
Old 03-28-2007, 10:24 AM
Bowman's Avatar
Bowman is on a distinguished road
Yep sounds like your pip tits are from the toolbit not being centered to the workpiece.
A trick is to take a small piece of shim stock and run the toolbit into the round workpiece with the shim inbetween. If the shim tilts up you need to lower your bit if it tilts down you need to raise the bit. when the shim stay vertical with little or no tilt you know your near dead center. This is just a quick way to tell where your at with the toolbit.
Bo
Old 03-28-2007, 10:26 AM
Thanks guys, So in a perfect world you wont have a tit?
Old 03-28-2007, 10:39 AM
cdlenterprises is on a distinguished road
Where are you trying to remove the tit from, the part or the remaining bar? I have never found a way to remove all of the cutoff tit from the part. I had always thought that was due to the material getting so weak at such a small diameter that it can't withstand the cutting pressure and breaks off. Slowing the feed down and using an angled cutoff tool vs. a straight or flat one can help to minimize the 'tit" but I haven't found a way to eliminate it. Maybe some of you screw machine guys can help out...
I don't know much about anything but I know a little about everything....
Old 03-28-2007, 11:26 AM
Bowman's Avatar
You may always get some sort of small tit due to the toolbit deflection pushing it slightly off centerline. And as Cdlenterprises noted the metal will get weak when you get down to the center especially depending on how big a piece is hanging off the end. We always cut through to nearly full depth then backed off and just broke the piece off by work hardening the little remaining connection spot with backand forth motion. Then just chuck up that end and face the part smooth.
Old 03-28-2007, 11:34 AM
cdlenterprises has it pretty well complete; as soon as the cutting force at the parting tool is greater than the strength of the remaining material the part breaks off leaving a tip on the parted off piece. Going very slow and having an angled parting tool will minimize it.
Depending on the depth of the part and the material it may be possible to have a large angle so the tip barely exists. Brass and Delrin are two materials that can be parted with a parting tool tip at around 45 degrees. Using any angle on aluminum and many other materials that generate stringy turnings rather than chips is almost impossible.
If you are doing this on a manual machine there may not be much you can do. I technique I have used with production work on a CNC lathe is part using a straight carbide tool down to a diameter large than the break-off size, then go in with a HSS parting tool that is thinner than the carbide and has a large angle to make the final cut and part off the piece with almost no tip. This does put an extra tool change in a cycle but the time taken here can be more than recovered by the time saved in deburring operations later on.
When parting off into a bore the tip is actually a ring that can have a really sharp edge and can be a real pain to deburr. A technique I have used is to use a threading tool to cut a vee groove inside the bore and then part down to meet the groove. When the parting tool edge is aligned nicely with the center of the groove the residual ring can be polished off with a quick swipe across a piece of fime emery on a flat surface.
Old 03-28-2007, 11:48 AM
My problem is that I am running several thousand parts and they are only 5/16 in dia and .6 long, kind of a pain to grind all of those tits. I will try slowing the feed down and see if that minimizes it at all. I would be happier if the tit were on the stock, then it wouldn't matter.
Old 03-28-2007, 11:51 AM
jackson's Avatar
jackson is on a distinguished road
try slowing the feed down and the speed right at the bottom, i do this and it helps alot
individual who perceives a solution and is willing to take command. Very often, that individual is crazy.
Don't spend time even doing this; put in two parting tools as I do.
  #11   Ban this user!
Old 03-28-2007, 11:54 AM
jackson's Avatar
Why 2?????
  #12   Ban this user!
Old 03-28-2007, 11:57 AM
Originally Posted by jackson View Post
Why 2?????
From Post #7 above:
"... technique I have used with production work on a CNC lathe is part using a straight carbide tool down to a diameter large than the break-off size, then go in with a HSS parting tool that is thinner than the carbide and has a large angle to make the final cut and part off the piece with almost no tip. This does put an extra tool change in a cycle but the time taken here can be more than recovered by the time saved in deburring operations later on..."
This is with material such as leaded steel and aluminum where doing the whole part using a large angle tool is not possible.
"low end" HF Spindle or "high end" router for about $1000? biomed_eng DIY-CNC Router Table Machines 14 01-06-2012 12:15 AM
CNC "KIT" for 8x12 8x14 mini lathe - or cheap/small CNC lathe? tinkering Mini Lathe 15 05-05-2011 05:59 PM
BattleAxe "aka" Ball and Chain "aka" the wife. ZipSnipe CNCzone Club House 48 05-18-2008 09:53 AM
Vertical system "jerks" and "bangs"?? REVCAM_Bob Servo Motors and Drives 5 06-12-2006 09:09 AM
12"X30" Lathe on Ebay, $1000 - good deal? mxtras General Metalwork Discussion 2 06-24-2005 10:12 AM
