Old 03-26-2007, 06:33 PM
pzzamakr1980 is on a distinguished road
Jacobs Taper 3 Machining
I just purchased a Tormach tooling system to use with my Sieg. I got everything I want with one little problem. I have a high quality keyless drill chuck with a JT3 mount. The problem is that Tormach doesnt sell a JT3 adaptor for use with their system. I believe I could make one since I purchased a great deal of tooling to go with my new lathe but I dont know the taper angle or how to figure it out. According to the wikipedia the small end is .7461 inches in diameter and the large end is .8110. The overall length is 1.2188. I know with this info you should be able to algebraically figure the angle out but I don't remember how. Anybody remember?
Old 04-03-2007, 11:23 AM
Crashmaster's Avatar
Crashmaster is on a distinguished road
Well, I am in the process of making one and you just let me know the dimensions
I needed. Dont quote me on this, but I believe the angle is 1.5251. I will let you
know for sure in a few hours after I make it and test it.
Old 04-03-2007, 03:20 PM
Thumbs up
Using those measurements you listed with a 1.5251 angle, sucker fit perfectly. I machined it using a CNC lathe so I was able to hold a .001 tolerance though. Good Luck.
What's the taper on this? la_coterie Commercial CNC Wood Routers 4 02-20-2010 02:15 PM
Pratt & Whitney, what JACOBS taper are on holders? MITYDR CNC Tooling 5 11-06-2006 09:46 PM
Morse versus Jacobs CoCoMedic General Metal Working Machines 2 10-18-2006 03:37 PM
Machining short taper tooling. davidmb General Metalwork Discussion 6 04-07-2006 05:25 PM
Machining anodized parts or anodize after machining? SRT Mike General Metalwork Discussion 4 03-11-2006 11:22 PM
